Ir para o conteúdo principal
Redmi Note 9 Pro - Reboots, Power On flex Replacement
O que você precisa
Vídeo de Apresentação
Xiaomi Redmi Note 9 Pro restarts - Power On flex replacement
  1. Redmi Note 9 Pro - Reboots, Power On flex Replacement, Back cover removal: passo 1, imagem 1 %32 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Back cover removal: passo 1, imagem 2 %32 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Back cover removal: passo 1, imagem 3 %32
    • Warm up the device to soften the adhesive.
    • Use plastic tools and a little isopropyl alcohol to separate the back cover.
  2. Redmi Note 9 Pro - Reboots, Power On flex Replacement, Motherboard plastic cover removal.: passo 2, imagem 1 %32 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Motherboard plastic cover removal.: passo 2, imagem 2 %32 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Motherboard plastic cover removal.: passo 2, imagem 3 %32
    • Remove the Phillips screws that secure the motherboard cover.
    • Use a plastic opening tool to remove the cover.
  3. Redmi Note 9 Pro - Reboots, Power On flex Replacement, Motherboard removal - part 1: passo 3, imagem 1 %32 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Motherboard removal - part 1: passo 3, imagem 2 %32 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Motherboard removal - part 1: passo 3, imagem 3 %32
    • Lift up the flex connector to disconnect the battery.
    • Remove the main cameras.
    • Remove the SIM tray.
  4. Redmi Note 9 Pro - Reboots, Power On flex Replacement, Motherboard removal - part 2: passo 4, imagem 1 %32 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Motherboard removal - part 2: passo 4, imagem 2 %32 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Motherboard removal - part 2: passo 4, imagem 3 %32
    • Disconnect all flex cables:
    • Fingerprint sensor flex cable
    • Screen flex cable
    • Main flex cable
    • Coaxial antenna cable
    • Remove the Phillips screws securing the motherboard to the middle frame
    • Remove the motherboard.
  5. Redmi Note 9 Pro - Reboots, Power On flex Replacement, Power on and volume buttons flex cable removal.: passo 5, imagem 1 %32 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Power on and volume buttons flex cable removal.: passo 5, imagem 2 %32 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Power on and volume buttons flex cable removal.: passo 5, imagem 3 %32
    • Remove the Fingerprint sensor.
    • Remove the volume buttons plastic cap.
    • Use isopropyl alcohol to help remove the glued down flex cable.
  6. Redmi Note 9 Pro - Reboots, Power On flex Replacement, Power on and volume buttons flex cable removal: passo 6, imagem 1 %32 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Power on and volume buttons flex cable removal: passo 6, imagem 2 %32 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Power on and volume buttons flex cable removal: passo 6, imagem 3 %32
    • Use playing cards to remove the flex cable.
Conclusão
6 outras pessoas executaram este guia.
ZFix
Membro desde: 12/09/13
191.882 Reputação
Autoria de 330 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 321
Autoria de 1.516 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 35
Últimos 30 dias: 216
Duração total: 4,619
