Introdução
The whammy bar spring can dislodge from its mounts causing the bar to lose tension. This guide will show you how to replace the whammy bar spring.
O que você precisa
Remove the strap by pulling it off of the mounts located on the body and neck.
Remove the two 7mm Phillips #2 screws from the black wire retainer.
Pull off the black wire retainer.
3 outras pessoas executaram este guia.
