Ir para o conteúdo principal
RedOctane X-Plorer Strum Bar Sensor Board Replacement
O que você precisa
  1. RedOctane X-Plorer Strum Bar Sensor Board Replacement, Rear Case: passo 1, imagem 1 %32 RedOctane X-Plorer Strum Bar Sensor Board Replacement, Rear Case: passo 1, imagem 2 %32
    • Remove the strap by pulling it off of the mounts located on the body and neck.
  2. RedOctane X-Plorer Strum Bar Sensor Board Replacement: passo 2, imagem 1 %32 RedOctane X-Plorer Strum Bar Sensor Board Replacement: passo 2, imagem 2 %32 RedOctane X-Plorer Strum Bar Sensor Board Replacement: passo 2, imagem 3 %32
    • Remove the nine 12mm Phillips #1 screws around the perimeter of the case with a screwdriver.
    • Remove the two 15mm Phillips #1 screws connecting the body panel to the neck panel with a screwdriver.
    • These screws can also be Torx on some models.
    • Pull off the rear case.
  3. RedOctane X-Plorer Strum Bar Sensor Board Replacement: passo 3, imagem 1 %32 RedOctane X-Plorer Strum Bar Sensor Board Replacement: passo 3, imagem 2 %32 RedOctane X-Plorer Strum Bar Sensor Board Replacement: passo 3, imagem 3 %32
    • Remove the five 12mm Phillips #1 screws along the neck with a screwdriver.
    • Pull off the top shell of the neck to expose the internal features.
  4. RedOctane X-Plorer Strum Bar Sensor Board Replacement, Strum Bar Sensor Board: passo 4, imagem 1 %32 RedOctane X-Plorer Strum Bar Sensor Board Replacement, Strum Bar Sensor Board: passo 4, imagem 2 %32 RedOctane X-Plorer Strum Bar Sensor Board Replacement, Strum Bar Sensor Board: passo 4, imagem 3 %32
    • Use a screwdriver to remove the four 14mm Phillips #1 screws around the perimeter of the strum bar sensor board.
    • Lift up on the strum bar sensor board to remove it from the case.
Conclusão
Uma outra pessoa concluiu este guia.
Riley
Membro desde: 04/18/18
649 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team S17-G1, Livingston Spring 2018 Membro de Cal Poly, Team S17-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G1
Membros da 3
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 43
Duração total: 2,636
