Ir para o conteúdo principal
RedOctane X-Plorer Strum Bar Replacement
O que você precisa
  1. RedOctane X-Plorer Strum Bar Replacement, Rear Case: passo 1, imagem 1 %32 RedOctane X-Plorer Strum Bar Replacement, Rear Case: passo 1, imagem 2 %32
    • Remove the strap by pulling it off of the mounts located on the body and neck.
  2. RedOctane X-Plorer Strum Bar Replacement: passo 2, imagem 1 %32 RedOctane X-Plorer Strum Bar Replacement: passo 2, imagem 2 %32 RedOctane X-Plorer Strum Bar Replacement: passo 2, imagem 3 %32
    • Remove the nine 12mm Phillips #1 screws around the perimeter of the case with a screwdriver.
    • Remove the two 15mm Phillips #1 screws connecting the body panel to the neck panel with a screwdriver.
    • These screws can also be Torx on some models.
    • Pull off the rear case.
  3. RedOctane X-Plorer Strum Bar Replacement: passo 3, imagem 1 %32 RedOctane X-Plorer Strum Bar Replacement: passo 3, imagem 2 %32 RedOctane X-Plorer Strum Bar Replacement: passo 3, imagem 3 %32
    • Remove the five 12mm Phillips #1 screws along the neck with a screwdriver.
    • Pull off the top shell of the neck to expose the internal features.
  4. RedOctane X-Plorer Strum Bar Replacement, Strum Bar: passo 4, imagem 1 %32
    • Using two hands, gently remove the two string rod fixtures.
  5. RedOctane X-Plorer Strum Bar Replacement: passo 5, imagem 1 %32
    • Lift up on the strum bar to remove it from the guitar.
  6. RedOctane X-Plorer Strum Bar Replacement: passo 6, imagem 1 %32 RedOctane X-Plorer Strum Bar Replacement: passo 6, imagem 2 %32
    • Remove the string rod by gently pulling it out of the strum bar.
Conclusão
4 outras pessoas executaram este guia.
Jared McMullen
Membro desde: 04/18/18
276 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S17-G1, Livingston Spring 2018 Membro de Cal Poly, Team S17-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G1
Membros da 3
Autoria de 9 guias
2 comentários
I had a squeaking strum bar so I followed this guide to dismantle and clean the parts. Other than the one step missed in the guide it was easy to follow. It also stopped the squeaking!
Zachary Avery - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 43
Duração total: 3,565
