Ir para o conteúdo principal
RedOctane X-Plorer Rubber Button Strip Replacement
O que você precisa
  1. RedOctane X-Plorer Rubber Button Strip Replacement, Rubber Button Strip: passo 1, imagem 1 %32 RedOctane X-Plorer Rubber Button Strip Replacement, Rubber Button Strip: passo 1, imagem 2 %32
    • Remove the controller's strap, which will be attached at the points in the red circles.
    • If your controller does not have a strap, move to the next step.
  2. RedOctane X-Plorer Rubber Button Strip Replacement: passo 2, imagem 1 %32
    • Remove all nine 12mm screws around the perimeter of the body of the controller, using the Phillips #2 screwdriver.
    • Remove the two 15mm screws near the neck of the controller, using the Phillips #2 screwdriver.
  3. RedOctane X-Plorer Rubber Button Strip Replacement: passo 3, imagem 1 %32 RedOctane X-Plorer Rubber Button Strip Replacement: passo 3, imagem 2 %32
    • Using your hands, remove the body shell.
  4. RedOctane X-Plorer Rubber Button Strip Replacement: passo 4, imagem 1 %32
    • Remove all seven 12mm screws on the neck of the controller using the Phillips #2 screwdriver.
  5. RedOctane X-Plorer Rubber Button Strip Replacement: passo 5, imagem 1 %32 RedOctane X-Plorer Rubber Button Strip Replacement: passo 5, imagem 2 %32
    • Using your hands, remove the top shell of neck.
  6. RedOctane X-Plorer Rubber Button Strip Replacement: passo 6, imagem 1 %32
    Ferramenta utilizada neste passo:
    Flathead 1.5 mm Screwdriver
    $5.49
    • Remove the left 1.5mm mm screw (as shown) on the key sensor board, using the 1.5mm flathead screwdriver.
    • Do not remove the other (right-side) screw on key sensor board, as this can cause damage to the circuitry.
  7. RedOctane X-Plorer Rubber Button Strip Replacement: passo 7, imagem 1 %32 RedOctane X-Plorer Rubber Button Strip Replacement: passo 7, imagem 2 %32
    • Using your hands, remove the rubber button strip.
  8. RedOctane X-Plorer Rubber Button Strip Replacement: passo 8, imagem 1 %32 RedOctane X-Plorer Rubber Button Strip Replacement: passo 8, imagem 2 %32
    • Using your hands, insert the replacement strip underneath the key sensor board.
  9. RedOctane X-Plorer Rubber Button Strip Replacement: passo 9, imagem 1 %32 RedOctane X-Plorer Rubber Button Strip Replacement: passo 9, imagem 2 %32
    • Align the black dots on the rubber strip with the corresponding button indicator before rescrewing key sensor board.
    • The first button will be "A" on Xbox and Wii, and "X" on Playstation.
Conclusão
Stephen Haning
Membro desde: 09/30/21
169 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Ao todo: 296
