Introdução
The guitar keys can wear out over time or stop working completely. This guide demonstrates how to successfully remove the keys to diagnose internal problems.
O que você precisa
Remove the strap by pulling it off of the mounts located on the body and neck.
Use a screwdriver to remove the 10 mm Phillips #1 screws from the key sensor board.
Lift up on the key sensor board to remove it from the guitar neck.
