Ir para o conteúdo principal
RedOctane X-Plorer Auxiliary Port Replacement
O que você precisa
  1. RedOctane X-Plorer Auxiliary Port Replacement, Rear Case: passo 1, imagem 1 %32 RedOctane X-Plorer Auxiliary Port Replacement, Rear Case: passo 1, imagem 2 %32
    • Remove the strap by pulling it off of the mounts located on the body and neck.
  2. RedOctane X-Plorer Auxiliary Port Replacement: passo 2, imagem 1 %32 RedOctane X-Plorer Auxiliary Port Replacement: passo 2, imagem 2 %32 RedOctane X-Plorer Auxiliary Port Replacement: passo 2, imagem 3 %32
    • Remove the nine 12mm Phillips #1 screws around the perimeter of the case with a screwdriver.
    • Remove the two 15mm Phillips #1 screws connecting the body panel to the neck panel with a screwdriver.
    • These screws can also be Torx on some models.
    • Pull off the rear case.
  3. RedOctane X-Plorer Auxiliary Port Replacement: passo 3, imagem 1 %32 RedOctane X-Plorer Auxiliary Port Replacement: passo 3, imagem 2 %32 RedOctane X-Plorer Auxiliary Port Replacement: passo 3, imagem 3 %32
    • Remove the five 12mm Phillips #1 screws along the neck with a screwdriver.
    • Pull off the top shell of the neck to expose the internal features.
  4. RedOctane X-Plorer Auxiliary Port Replacement, Auxiliary Port: passo 4, imagem 1 %32 RedOctane X-Plorer Auxiliary Port Replacement, Auxiliary Port: passo 4, imagem 2 %32 RedOctane X-Plorer Auxiliary Port Replacement, Auxiliary Port: passo 4, imagem 3 %32
    • Remove the two 10mm Phillips #1 screws from the auxiliary port board using a screwdriver.
    • Gently lift up on the auxiliary port to remove it from the case.
Conclusão
Riley
Membro desde: 04/18/18
649 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team S17-G1, Livingston Spring 2018 Membro de Cal Poly, Team S17-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G1
Membros da 3
Autoria de 9 guias
Um comentário
What does the neck have to do with this? You mention it in the intro and step 3, but I don’t get why you’d need to open up the neck at all for this repair.
Tuesday - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 11
Duração total: 1,146
