Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
You can easily access the auxiliary port through the guitar neck. This guide will show you how to replace the auxiliary port located at the bottom of the guitar.
Peças
Nenhum componente especificado.
  1. Remove the strap by pulling it off of the mounts located on the body and neck. Remove the strap by pulling it off of the mounts located on the body and neck.
    • Remove the strap by pulling it off of the mounts located on the body and neck.
  2. Remove the nine 12mm Phillips #1 screws around the perimeter of the case with a  screwdriver. Remove the two 15mm Phillips #1 screws connecting the body panel to the neck panel with a screwdriver. These screws can also be Torx on some models.
    • Remove the nine 12mm Phillips #1 screws around the perimeter of the case with a screwdriver.
    • Remove the two 15mm Phillips #1 screws connecting the body panel to the neck panel with a screwdriver.
    • These screws can also be Torx on some models.
    • Pull off the rear case.
  3. Kit de pontas universal para chave
    112 bits for every fix.
    Upgrade Your Toolbox
  4. Remove the five 12mm Phillips #1 screws along the neck with a  screwdriver. Pull off the top shell of the neck to expose the internal features. Pull off the top shell of the neck to expose the internal features.
    • Remove the five 12mm Phillips #1 screws along the neck with a screwdriver.
    • Pull off the top shell of the neck to expose the internal features.
  5. Remove the two 10mm Phillips #1 screws from the auxiliary port board using a  screwdriver. Gently lift up on the auxiliary port to remove it from the case. Gently lift up on the auxiliary port to remove it from the case.
    • Remove the two 10mm Phillips #1 screws from the auxiliary port board using a screwdriver.
    • Gently lift up on the auxiliary port to remove it from the case.
Conclusão
Riley
Membro desde: 18-04-2018
610 Reputação
7 Guias de autoria
Equipe
Cal Poly, Team S17-G1, Livingston Spring 2018 Membro de Cal Poly, Team S17-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G1
3 Membros
9 Guias de autoria
What does the neck have to do with this? You mention it in the intro and step 3, but I don’t get why you’d need to open up the neck at all for this repair.
Timothy - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 19
Duração total: 364
