Ir para o conteúdo principal
Recharging A/C Refrigerant for 2016 Hyundai Elantra
O que você precisa
  1. Recharging A/C Refrigerant for 2016 Hyundai Elantra, Recharging A/C Refrigerant for 2016 Hyundai Elantra: passo 1, imagem 1 %32
    • Get refrigerant and read the pressure chart carefully. This is located on the side of the can.
  2. Recharging A/C Refrigerant for 2016 Hyundai Elantra: passo 2, imagem 1 %32 Recharging A/C Refrigerant for 2016 Hyundai Elantra: passo 2, imagem 2 %32 Recharging A/C Refrigerant for 2016 Hyundai Elantra: passo 2, imagem 3 %32
    • Find and pull the lever to the hood on the driver's side of the vehicle.
  3. Recharging A/C Refrigerant for 2016 Hyundai Elantra: passo 3, imagem 1 %32 Recharging A/C Refrigerant for 2016 Hyundai Elantra: passo 3, imagem 2 %32 Recharging A/C Refrigerant for 2016 Hyundai Elantra: passo 3, imagem 3 %32
    • Lift the hood while pulling the lever under the center of the hood. Next, prop up the hood with the hood strut.
  4. Recharging A/C Refrigerant for 2016 Hyundai Elantra: passo 4, imagem 1 %32 Recharging A/C Refrigerant for 2016 Hyundai Elantra: passo 4, imagem 2 %32
    • Locate the low-pressure port by following the low-pressure hose (the cap will have an "L" on it).
  5. Recharging A/C Refrigerant for 2016 Hyundai Elantra: passo 5, imagem 1 %32 Recharging A/C Refrigerant for 2016 Hyundai Elantra: passo 5, imagem 2 %32
    • Shake the can well.
  6. Recharging A/C Refrigerant for 2016 Hyundai Elantra: passo 6, imagem 1 %32
    • Connect the refrigerant hose to the low-pressure port.
  7. Recharging A/C Refrigerant for 2016 Hyundai Elantra: passo 7, imagem 1 %32
    • Start the vehicle and turn on the A/C all the way on.
  8. Recharging A/C Refrigerant for 2016 Hyundai Elantra: passo 8, imagem 1 %32 Recharging A/C Refrigerant for 2016 Hyundai Elantra: passo 8, imagem 2 %32 Recharging A/C Refrigerant for 2016 Hyundai Elantra: passo 8, imagem 3 %32
    • While tipping the can 90 degrees back and forth, fill your vehicle (until the gauge reads as the can specifies).
Conclusão
To recharge your vehicle, follow these instructions in order.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 21
Últimos 7 dias: 124
Últimos 30 dias: 501
Duração total: 7,001
