Ir para o conteúdo principal
Reattaching the GEN 2 Wheelchair Foot Support
O que você precisa
  1. Reattaching the GEN 2 Wheelchair Foot Support, Foot Support: passo 1, imagem 1 %32 Reattaching the GEN 2 Wheelchair Foot Support, Foot Support: passo 1, imagem 2 %32 Reattaching the GEN 2 Wheelchair Foot Support, Foot Support: passo 1, imagem 3 %32
    • Slide the footrest sockets down as shown and use a 10 mm wrench to tighten the bolts at the desired height.
  2. Reattaching the GEN 2 Wheelchair Foot Support: passo 2, imagem 1 %32
    • Screw in the bolt to the top socket to secure the height of the footrest.
  3. Reattaching the GEN 2 Wheelchair Foot Support: passo 3, imagem 1 %32 Reattaching the GEN 2 Wheelchair Foot Support: passo 3, imagem 2 %32
    • Screw in the bolt attaching the footrest to the frame.
    • Screw in the lower bolt to the footrest.
Conclusão
Check that the footrest is at the desired height. If the footrest is still uncomfortable start the guide over again from step 1 using a different height to tighten bolts.
Kali Slaughter
Membro desde: 04/19/13
207 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 14-8, Maness Spring 2013 Membro de Cal Poly, Team 14-8, Maness Spring 2013
CPSU-MANESS-S13S14G8
Membros da 5
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 801
