Ir para o conteúdo principal
Realigning 12-Inch Bionaire Fan Metal Coil
O que você precisa
  1. Realigning 12-Inch Bionaire Fan Metal Coil, Realigning 12-Inch Bionaire Fan Metal Coil: passo 1, imagem 1 %32 Realigning 12-Inch Bionaire Fan Metal Coil, Realigning 12-Inch Bionaire Fan Metal Coil: passo 1, imagem 2 %32
    • Unlock all of the tabs holding the fan cage together.
    • Carefully pull off the cage.
  2. Realigning 12-Inch Bionaire Fan Metal Coil: passo 2, imagem 1 %32 Realigning 12-Inch Bionaire Fan Metal Coil: passo 2, imagem 2 %32
    • Using a Phillips #2 screwdriver, untighten the 1/4'' screw that is located underneath the fan blade.
    • Blade may be sharp so watch out!
    • Cautiously remove the blade from the hinge.
    • Put the screws in a cup so you don't lose them!
  3. Realigning 12-Inch Bionaire Fan Metal Coil: passo 3, imagem 1 %32 Realigning 12-Inch Bionaire Fan Metal Coil: passo 3, imagem 2 %32
    • Rotate the black cap counter-clockwise to disconnect it from the back fan cage.
    • Pull off the back cage from the engine holder.
  4. Realigning 12-Inch Bionaire Fan Metal Coil: passo 4, imagem 1 %32
    • Working with the Phillips #2 screwdriver, loosen the 1/4'' center hinge screw from the metal base.
  5. Realigning 12-Inch Bionaire Fan Metal Coil: passo 5, imagem 1 %32 Realigning 12-Inch Bionaire Fan Metal Coil: passo 5, imagem 2 %32
    • Using the Phillips #2 screwdriver, separate the wire holder from the back of black cover by removing the two 1/8'' screws.
  6. Realigning 12-Inch Bionaire Fan Metal Coil: passo 6, imagem 1 %32 Realigning 12-Inch Bionaire Fan Metal Coil: passo 6, imagem 2 %32
    • Pull of the black knob by rotating the knob counter-clockwise.
    • Pull down the black cover all the way.
    • The coil may pop out after removing the cover.
  7. Realigning 12-Inch Bionaire Fan Metal Coil: passo 7, imagem 1 %32 Realigning 12-Inch Bionaire Fan Metal Coil: passo 7, imagem 2 %32
    • Take out the gold metal spring.
    • Realign the metal coil into designated space.
    • Push the coil in with some force so it rests perfectly in the space.
    • To make placing the coil back in more easier, use the screwdriver!
  8. Realigning 12-Inch Bionaire Fan Metal Coil: passo 8, imagem 1 %32 Realigning 12-Inch Bionaire Fan Metal Coil: passo 8, imagem 2 %32
    • Align the end of the metal coil into the same hole the black wire comes out of in the black cover from step 6.
    • This can be a frustrating step. Be patient!
Conclusão
3 outras pessoas executaram este guia.
Hemish Patel
Membro desde: 09/29/15
231 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 10-3, Green Fall 2015 Membro de Cal Poly, Team 10-3, Green Fall 2015
CPSU-GREEN-F15S10G3
Membros da 4
Autoria de 4 guias
Um comentário
I have a fan It hum I have to spin the blade for it to start spin
Chris - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 26
Duração total: 3,784
