Ir para o conteúdo principal
RazorX DLX Electric Skateboard Charging Port Replacement
O que você precisa
  1. RazorX DLX Electric Skateboard Charging Port Replacement, Battery: passo 1, imagem 1 %32 RazorX DLX Electric Skateboard Charging Port Replacement, Battery: passo 1, imagem 2 %32 RazorX DLX Electric Skateboard Charging Port Replacement, Battery: passo 1, imagem 3 %32
    • Flip the skateboard upside down.
    • Use a 4 mm Allen key to remove the 25 mm bolt that secures the cover.
    • Push the cover forward to slide it off.
  2. RazorX DLX Electric Skateboard Charging Port Replacement: passo 2, imagem 1 %32
    • Disconnect the battery and slide it out.
    • Lithium-ion batteries should not be punctured, heated or improperly disposed of.
  3. RazorX DLX Electric Skateboard Charging Port Replacement, Control Module: passo 3, imagem 1 %32 RazorX DLX Electric Skateboard Charging Port Replacement, Control Module: passo 3, imagem 2 %32 RazorX DLX Electric Skateboard Charging Port Replacement, Control Module: passo 3, imagem 3 %32
    • Flip the skateboard back over.
    • Remove the six 22 mm bolts indicated on the top side of the skateboard with a 3 mm Allen key.
    • While holding the nut from the underside of the skateboard remove the four 32 mm bolts with the 3 mm Allen key.
    • Separate the trucks and control module from the board.
  4. RazorX DLX Electric Skateboard Charging Port Replacement: passo 4, imagem 1 %32 RazorX DLX Electric Skateboard Charging Port Replacement: passo 4, imagem 2 %32 RazorX DLX Electric Skateboard Charging Port Replacement: passo 4, imagem 3 %32
    • Remove the four 20 mm bolts using a 4 mm Allen key, then remove the metal plate to separate the motor from the trucks.
    • Separate the wheel motor from the trucks
  5. RazorX DLX Electric Skateboard Charging Port Replacement: passo 5, imagem 1 %32
    • Remove the two 15 mm Phillips #00 screws to free the motor cable.
    • Remove the two 15 mm Phillips #00 screws securing the battery cage.
    • You will still need to remove the standoffs to fully remove the battery cage.
  6. RazorX DLX Electric Skateboard Charging Port Replacement: passo 6, imagem 1 %32 RazorX DLX Electric Skateboard Charging Port Replacement: passo 6, imagem 2 %32 RazorX DLX Electric Skateboard Charging Port Replacement: passo 6, imagem 3 %32
    • Remove the two standoffs holding the battery cage in place with an 8 mm wrench.
    • The standoffs have a nylon washer on either side of the battery cage.
    • Lift the battery cage up and out of the control module.
  7. RazorX DLX Electric Skateboard Charging Port Replacement: passo 7, imagem 1 %32 RazorX DLX Electric Skateboard Charging Port Replacement: passo 7, imagem 2 %32 RazorX DLX Electric Skateboard Charging Port Replacement: passo 7, imagem 3 %32
    • Remove the 20 mm Phillips #0 screw.
    • Disconnect the DC connector. The DC connector can be identified as the connector with only two wires.
    • Disconnect the power button. It is a temporary switch, which can be identified by its 4-wire configuration.
    • Disconnect the Hall effect sensor. It can be identified by its 6-wire configuration.
    • A hall effect sensor is used to tell the board where the motor is in its rotation.
    • You will need to remove silicone and hot glue to remove the connectors.
  8. RazorX DLX Electric Skateboard Charging Port Replacement: passo 8, imagem 1 %32 RazorX DLX Electric Skateboard Charging Port Replacement: passo 8, imagem 2 %32
    • Disconnect the three green butt connectors.
    • These connectors will require a decent amount of force to pull them apart.
  9. RazorX DLX Electric Skateboard Charging Port Replacement: passo 9, imagem 1 %32
    • Remove the Control Module by lifting it out of the plastic housing.
  10. RazorX DLX Electric Skateboard Charging Port Replacement, Charging Port: passo 10, imagem 1 %32 RazorX DLX Electric Skateboard Charging Port Replacement, Charging Port: passo 10, imagem 2 %32 RazorX DLX Electric Skateboard Charging Port Replacement, Charging Port: passo 10, imagem 3 %32
    • Disconnect the charging port.
    • Remove the retaining nut.
    • Pull the charging port out of the plastic body.
Conclusão
Emmett Normand
Membro desde: 10/24/24
971 Reputação
Autoria de 8 guias
Equipe
Cuesta, Team 20-4, Krynen Fall 2024 Membro de Cuesta, Team 20-4, Krynen Fall 2024
CUESTA-KRYNEN-F24S20G4
Membros da 5
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 35
