Introdução
If your Razor AW Kick Scooter has a worn out wheel bar or the wheel bar is disturbing your performance, follow this guide to replace it or remove it altogether.
The wheel bar is a scooter part that can be used for performing tricks or as a footrest stand when using the scooter for transportation.
O que você precisa
Place the scooter on its side and on the ground.
Place the 5 mm Hex Security key into the screw, and secure the other side of the screw with another 5 mm Hex Security key to keep it from spinning around.
Remove the screw using the 5 mm Hex Security key.
Remove the screw from the scooter frame.
To reassemble your device, follow these instructions in revise order.
