Ir para o conteúdo principal
Razor A Handle Grips Replacement
O que você precisa
  1. Razor A Handle Grips Replacement, Handle Grips: passo 1, imagem 1 %32 Razor A Handle Grips Replacement, Handle Grips: passo 1, imagem 2 %32
    • If the scooter does not already have handle grips, skip to step 2.
    • Locate the handle grips at the upper ends of the T-tube.
    • Be careful to keep the scissors away from your other hand while cutting the handle grips.
    • Wedge one end of a pair of scissors between the metal T-tube and a handle grip, with the cutting edge toward the handle grip. Cut the handle grip off.
    • Repeat for the other handle grip.
  2. Razor A Handle Grips Replacement: passo 2, imagem 1 %32 Razor A Handle Grips Replacement: passo 2, imagem 2 %32
    • Soak the replacement handle grips in warm water for 2-3 minutes.
    • The longer you soak the handle grips in water, the larger they get. Soaking the handle grips for a long time will not damage them.
  3. Razor A Handle Grips Replacement: passo 3, imagem 1 %32 Razor A Handle Grips Replacement: passo 3, imagem 2 %32
    • Each handle grip should now slide onto the T-tube with ease. If not, soak the handle grip(s) in warm water for another 1-3 minutes.
    • Holding the T-tube with one hand, slide a handle grip completely onto the T-tube.
    • Repeat for the other handle grip if installing both.
    • Let the handle grips dry for 24 hours before use.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Jordyn
Membro desde: 10/09/12
544 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 9-13, Amido Fall 2012 Membro de Cal Poly, Team 9-13, Amido Fall 2012
CPSU-AMIDO-F12S9G13
Membros da 4
Autoria de 10 guias
Um comentário
I have found the Razor A5 Lux Scooter the best kick scooter for daily commuting.
Mathew Sam - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 24
Duração total: 4,806
