Ir para o conteúdo principal
Razer Wildcat Xbox One Controller Disassembly
O que você precisa
  1. Razer Wildcat Xbox One Controller Disassembly, Remove grip plates: passo 1, imagem 1 %32 Razer Wildcat Xbox One Controller Disassembly, Remove grip plates: passo 1, imagem 2 %32
    • Use a plastic pry tool to remove the grip plate from each side
    • The plate will release away from the back, not to the side
  2. Razer Wildcat Xbox One Controller Disassembly, Remove the back plate: passo 2, imagem 1 %32 Razer Wildcat Xbox One Controller Disassembly, Remove the back plate: passo 2, imagem 2 %32 Razer Wildcat Xbox One Controller Disassembly, Remove the back plate: passo 2, imagem 3 %32
    • Cut the sticker covering the center screw and remove it (PH #1)
    • Remove two screws from each grip (PH #1)
    • Use a plastic pry tool to remove rear plate from the controller
    • The three remaining screws on the back plate are PH #1
  3. Razer Wildcat Xbox One Controller Disassembly, Disassemble the board: passo 3, imagem 1 %32 Razer Wildcat Xbox One Controller Disassembly, Disassemble the board: passo 3, imagem 2 %32
    • Remove the M1 & M2 bumpers with two PH #1 screws (red)
    • Unplug the four rumble motors (green)
    • Unscrew the board from the controller with two PH #2 screws (blue)
    • Carefully flip the board until you can get to the ribbon cable
    • Flip the gray clip up to release the ribbon cable
  4. Razer Wildcat Xbox One Controller Disassembly, Remove the triggers: passo 4, imagem 1 %32 Razer Wildcat Xbox One Controller Disassembly, Remove the triggers: passo 4, imagem 2 %32 Razer Wildcat Xbox One Controller Disassembly, Remove the triggers: passo 4, imagem 3 %32
    • Remove the two PH #00 screws to remove the trigger brackets
    • Slide the trigger pin out just enough to remove it, leave the spring attached
    • The three remaining screws on each trigger are PH #1
  5. Razer Wildcat Xbox One Controller Disassembly, Remove the bumpers: passo 5, imagem 1 %32
    • Remove the bumper assembly from the controller
    • The bumpers detach with two PH #1 screws
Conclusão
Drew
Membro desde: 11/13/24
181 Reputação
Autoria de 1 guia
3Comentários do guia
I have done everything, but how do i remove the thumbstick plastic, it would be very great if you can guide me
Daniburazz - Responder
I didn't remove my thumbsticks. They are likely glued on. You could try to pry them off or use heat but you are on your own for that.
Drew -
You can´t change the thumbsticks, they are stuck and impossible to remove. I broke one of them trying to get it out. It's okay because I want to replace them with magnetic ones and I'm looking at how to do it and compatible modules.
David “Grey Wolf” - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 43
Ao todo: 768
