Introdução
The keyboard on the Razer Tartarus V2, model number RZ07-02270100-R3U1, holds the keys in place and helps with the "click" when you press down a key. The main white frame or the metal contacts of the keyboard can be damaged by excessive force when pressing keys. This replacement guide is designed to help you restore your Key bed's performance and extend the overall lifespan of your device.
O que você precisa
To take off the keys, place the flat end of the opening tool under the edge of the key. Gently pry the key cap off of the board.
Remove the entire key bed, flip the top casing over.
Remove the four screws securing the key bed from the back using a Phillips #0 screwdriver.
