Ir para o conteúdo principal
Razer Phone Display Assembly Replacement
O que você precisa
  1. Razer Phone Display Assembly Replacement, Display Assembly: passo 1, imagem 1 %32 Razer Phone Display Assembly Replacement, Display Assembly: passo 1, imagem 2 %32 Razer Phone Display Assembly Replacement, Display Assembly: passo 1, imagem 3 %32
    • Remove the plastic speaker grills by using the metal spudger to pry underneath the strips.
    • Peel off the plastic speaker grill to reveal the screws.
    • Heating up the plastic grills make them easier to remove.
    • Peeling off the plastic speaker grill will ruin the adhesive used to keep it in place. A new adhesive must be used to put the grill back on the device.
  2. Razer Phone Display Assembly Replacement: passo 2, imagem 1 %32 Razer Phone Display Assembly Replacement: passo 2, imagem 2 %32
    • Pry the top plastic grill off with the metal spudger and reveal the screws.
  3. Razer Phone Display Assembly Replacement: passo 3, imagem 1 %32 Razer Phone Display Assembly Replacement: passo 3, imagem 2 %32 Razer Phone Display Assembly Replacement: passo 3, imagem 3 %32
    • Remove five (two bottom, three top) 2.5 mm screws with the Phillips #000 screwdriver.
    • Remove five (four bottom, one top) 5.5 mm screws with the Torx Head T5 screwdriver.
  4. Razer Phone Display Assembly Replacement: passo 4, imagem 1 %32 Razer Phone Display Assembly Replacement: passo 4, imagem 2 %32
    • Remove the display assembly by using the Jimmy to separate the assembly from the phone's frame.
    • Lift the display assembly away from the other half of the phone.
  5. Razer Phone Display Assembly Replacement: passo 5, imagem 1 %32 Razer Phone Display Assembly Replacement: passo 5, imagem 2 %32 Razer Phone Display Assembly Replacement: passo 5, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Remove one 2.5 mm screw holding down the metal bracket connector using the Phillips #000 screwdriver.
    • Peel back the metallic shielding over the connector using tweezers.
    • Remove the metal bracket connector.
  6. Razer Phone Display Assembly Replacement: passo 6, imagem 1 %32 Razer Phone Display Assembly Replacement: passo 6, imagem 2 %32
    • Grab hold of the the screen ribbon with the tweezers and remove it from the rest of the phone to free the assembly display.
Conclusão
10 outras pessoas executaram este guia.
Equipe
Cal Poly, Team S19-G6, White Winter 2019 Membro de Cal Poly, Team S19-G6, White Winter 2019
CPSU-WHITE-W19S19G6
Membros da 5
Autoria de 12 guias
14 comentários
“Peeling off the plastic speaker grill will ruin the adhesive used to keep it in place. A new adhesive must be used to put the grill back on the device.”
Any suggestions on what adhesive to use to replace the plastic speaker grills?
Vincent - Responder
Double sided tape.
Lucano -
Sir, where can I order Razer Phone 1 LCD Assembly?
baby_zhent17 - Responder
Search on eBay. Phones are often parted out there.
Lucano -
I almost forgot; when searching, your Razer Phone's model number is RZ35-0215, code name: Cheryl.
Lucano -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 76
Duração total: 15,205
