Ir para o conteúdo principal
Razer Naga Trinity LK-E5 Optical Encoder Replacement
O que você precisa
  1. Razer Naga Trinity LK-E5 Optical Encoder Replacement, Razer Naga Trinity Disassembly: passo 1, imagem 1 %32 Razer Naga Trinity LK-E5 Optical Encoder Replacement, Razer Naga Trinity Disassembly: passo 1, imagem 2 %32
    • Remove the interchangeable side plate.
  2. Razer Naga Trinity LK-E5 Optical Encoder Replacement: passo 2, imagem 1 %32 Razer Naga Trinity LK-E5 Optical Encoder Replacement: passo 2, imagem 2 %32
    • Remove the mouse's feet using the opening pick.
  3. Razer Naga Trinity LK-E5 Optical Encoder Replacement: passo 3, imagem 1 %32
    • Remove the four 6mm screws by using a JIS #1 screwdriver.
  4. Razer Naga Trinity LK-E5 Optical Encoder Replacement: passo 4, imagem 1 %32 Razer Naga Trinity LK-E5 Optical Encoder Replacement: passo 4, imagem 2 %32
    • Separate the top mouse housing from the bottom mouse housing using the opening pick.
    • Be careful not to tug too hard on the ribbon connector.
  5. Razer Naga Trinity LK-E5 Optical Encoder Replacement: passo 5, imagem 1 %32
    • Unlock the ribbon connector that is held down by the main board clips using the spudger's pointed end.
  6. Razer Naga Trinity LK-E5 Optical Encoder Replacement: passo 6, imagem 1 %32
    • Remove the side housing using the opening pick.
  7. Razer Naga Trinity LK-E5 Optical Encoder Replacement: passo 7, imagem 1 %32 Razer Naga Trinity LK-E5 Optical Encoder Replacement: passo 7, imagem 2 %32
    • Remove the top housing LED 3-Pin connector that is near the main board.
  8. Razer Naga Trinity LK-E5 Optical Encoder Replacement, Scroll Wheel Housing: passo 8, imagem 1 %32 Razer Naga Trinity LK-E5 Optical Encoder Replacement, Scroll Wheel Housing: passo 8, imagem 2 %32
    • Remove one 4mm black Phillips #000 screw from the left side of the mouse holding the scroll wheel LED controller board.
    • Then pull the LED controller board upwards and out.
  9. Razer Naga Trinity LK-E5 Optical Encoder Replacement: passo 9, imagem 1 %32
    • Pry and remove the scroll wheel feedback bar from its hold-down clips using the hook end of a halberd spudger.
  10. Razer Naga Trinity LK-E5 Optical Encoder Replacement: passo 10, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Remove the scroll wheel feedback bar from the scroll wheel by holding down the spring and using angled tweezers to remove it from its placement.
  11. Razer Naga Trinity LK-E5 Optical Encoder Replacement: passo 11, imagem 1 %32 Razer Naga Trinity LK-E5 Optical Encoder Replacement: passo 11, imagem 2 %32
    • Remove the scroll wheel optical encoder 3-pin connector from the main board by wiggling the connector upwards.
  12. Razer Naga Trinity LK-E5 Optical Encoder Replacement: passo 12, imagem 1 %32 Razer Naga Trinity LK-E5 Optical Encoder Replacement: passo 12, imagem 2 %32 Razer Naga Trinity LK-E5 Optical Encoder Replacement: passo 12, imagem 3 %32
    • Using the opening tool, pry the black bracket holding the scroll wheel in place backwards until the scroll wheel housing pops out.
  13. Razer Naga Trinity LK-E5 Optical Encoder Replacement, LK-E5 Optical Encoder: passo 13, imagem 1 %32 Razer Naga Trinity LK-E5 Optical Encoder Replacement, LK-E5 Optical Encoder: passo 13, imagem 2 %32
    • Remove the scroll wheel from the scroll wheel housing using the opening tool.
  14. Razer Naga Trinity LK-E5 Optical Encoder Replacement: passo 14, imagem 1 %32 Razer Naga Trinity LK-E5 Optical Encoder Replacement: passo 14, imagem 2 %32
    • Remove the scroll wheel optical encoder from the scroll wheel.
Conclusão
Uma outra pessoa concluiu este guia.
Um comentário
Where can we buy a replacement from?
Daniel - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 15
Últimos 30 dias: 58
Duração total: 2,137
