Introdução
If the LED on the mouse will not illuminate, the LED light ribbon cable might be disconnected or might need to be replaced. Reasons that the LED light ribbon may be non-functional is that the mouse drive could be out of date, there could be a physical issue with the ribbon cable, or there could be a connection issue. This guide will list all required steps to properly replace the LED light ribbon cable from the Razer Naga Trinity.
O que você precisa
Using the flat end of a spudger, unlock the ribbon cable holding the clips.
Remove the ribbon cable.
