Ir para o conteúdo principal
Razer Naga Trinity LED Light Ribbon Cable Replacement
O que você precisa
  1. Razer Naga Trinity LED Light Ribbon Cable Replacement, Razer Naga Trinity Disassembly: passo 1, imagem 1 %32 Razer Naga Trinity LED Light Ribbon Cable Replacement, Razer Naga Trinity Disassembly: passo 1, imagem 2 %32
    • Remove the interchangeable side plate.
  2. Razer Naga Trinity LED Light Ribbon Cable Replacement: passo 2, imagem 1 %32 Razer Naga Trinity LED Light Ribbon Cable Replacement: passo 2, imagem 2 %32
    • Remove the mouse's feet using the opening pick.
  3. Razer Naga Trinity LED Light Ribbon Cable Replacement: passo 3, imagem 1 %32
    • Remove the four 6mm screws by using a JIS #1 screwdriver.
  4. Razer Naga Trinity LED Light Ribbon Cable Replacement: passo 4, imagem 1 %32 Razer Naga Trinity LED Light Ribbon Cable Replacement: passo 4, imagem 2 %32
    • Separate the top mouse housing from the bottom mouse housing using the opening pick.
    • Be careful not to tug too hard on the ribbon connector.
  5. Razer Naga Trinity LED Light Ribbon Cable Replacement: passo 5, imagem 1 %32
    • Unlock the ribbon connector that is held down by the main board clips using the spudger's pointed end.
  6. Razer Naga Trinity LED Light Ribbon Cable Replacement: passo 6, imagem 1 %32
    • Remove the side housing using the opening pick.
  7. Razer Naga Trinity LED Light Ribbon Cable Replacement: passo 7, imagem 1 %32 Razer Naga Trinity LED Light Ribbon Cable Replacement: passo 7, imagem 2 %32
    • Remove the top housing LED 3-Pin connector that is near the main board.
  8. Razer Naga Trinity LED Light Ribbon Cable Replacement, LED Light Ribbon Cable: passo 8, imagem 1 %32 Razer Naga Trinity LED Light Ribbon Cable Replacement, LED Light Ribbon Cable: passo 8, imagem 2 %32
    • Using the flat end of a spudger, unlock the ribbon cable holding the clips.
    • Remove the ribbon cable.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 23
Duração total: 1,522
