Ir para o conteúdo principal
Razer Naga Expert MMO Top Plastic Shell Replacement
O que você precisa
  1. Razer Naga Expert MMO Top Plastic Shell Replacement, Top Plastic Shell: passo 1, imagem 1 %32
    • Peel back the two teflon tape from the top corners and the one larger one from the bottom with a spudger.
  2. Razer Naga Expert MMO Top Plastic Shell Replacement: passo 2, imagem 1 %32
    • Remove the four 7mm screws using a Phillips #00 screwdriver.
  3. Razer Naga Expert MMO Top Plastic Shell Replacement: passo 3, imagem 1 %32
    • Gently remove the top plastic plate of the mouse.
    • Unplug the white cord from the circuit board.
  4. Razer Naga Expert MMO Top Plastic Shell Replacement: passo 4, imagem 1 %32
    • Lightly pull the two plastic sides of the mouse to remove them.
Conclusão
5 outras pessoas executaram este guia.
2 comentários
do you know where i can get a new top body section? i have a molten that stopped left clicking on every click, i opened it up and the plastic pretty much was worn away
pipsqueak642 - Responder
i’m after the rubber adhesive for the side of this mouse if any one knows where to buy it from cheers.
mayo22 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 31
Duração total: 1,842
