Pular para o conteúdo principal
Introdução
This guide will help you replace the top outer casing of the mouse that holds some of the electronics for the LED lighting. Be sure to use caution when unplugging the wires, for this could result in the mouse not working properly. Also use caution when removing the plastic shell, it is fragile and it could be cracked upon removal.
Peças
Nenhum componente especificado.
  1. Peel back the two teflon tape from the top corners and the one larger one from the bottom with a spudger.
    • Peel back the two teflon tape from the top corners and the one larger one from the bottom with a spudger.
  2. Remove the four 7mm screws using a Phillips head #00 screwdriver.
    • Remove the four 7mm screws using a Phillips head #00 screwdriver.
  3. PC Laptop Batteries
    An easy fix for a big power boost.
    Comprar agora
    PC Laptop Batteries
    Comprar agora
  4. Gently remove the top plastic plate of the mouse.
    • Gently remove the top plastic plate of the mouse.
    • Unplug the white cord from the circuit board.
  5. Lightly pull the two plastic sides of the mouse to remove them.
    • Lightly pull the two plastic sides of the mouse to remove them.
Conclusão
4 outras pessoas concluíram este guia.
Gianni Conti
Membro desde: 29-01-2018
401 reputação
2 Guias de autoria
do you know where i can get a new top body section? i have a molten that stopped left clicking on every click, i opened it up and the plastic pretty much was worn away
pipsqueak642 - Responder
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 38
Todo: 593
