Pular para o conteúdo principal
Introdução
This guide will help you replace the motherboard which allows your mouse to function . Be sure to keep track of the 5mm screws and the 7mm screws.
Peças
Nenhum componente especificado.
  1. Peel back the two teflon tape from the top corners and the one larger one from the bottom with a spudger.
    • Peel back the two teflon tape from the top corners and the one larger one from the bottom with a spudger.
  2. Remove the four 7mm screws using a Phillips head #00 screwdriver.
    • Remove the four 7mm screws using a Phillips head #00 screwdriver.
  3. Gently remove the top plastic plate of the mouse.
    • Gently remove the top plastic plate of the mouse.
    • Unplug the white cord from the circuit board.
  4. Lightly pull the two plastic sides of the mouse to remove them.
    • Lightly pull the two plastic sides of the mouse to remove them.
  5. iPhone X Fix Kits
    Warranty up? No worries, we’ve got the fix.
    Comprar agora
    iPhone X Fix Kits
    Comprar agora
  6. Remove the 5mm screw holding the scroll wheel in place with a Phillips head #00 screwdriver.
    • Remove the 5mm screw holding the scroll wheel in place with a Phillips head #00 screwdriver.
  7. Unplug the cord that connects the scroll wheel to the circuit board.
    • Unplug the cord that connects the scroll wheel to the circuit board.
  8. Slide the chip out of the scroll wheel.
    • Slide the chip out of the scroll wheel.
  9. Gently wiggle the scroll wheel up and back to remove the scroll wheel from the mouse. Use your fingers to simultaneously push the scroll wheel and its frame forward and pull back on the plastic tab directly behind the scroll wheel until it is loose.
    • Gently wiggle the scroll wheel up and back to remove the scroll wheel from the mouse.
    • Use your fingers to simultaneously push the scroll wheel and its frame forward and pull back on the plastic tab directly behind the scroll wheel until it is loose.
    • Use your thumbs to pop the scroll wheel out from its plastic frame.
  10. Place the new scroll wheel in the mount.
    • Place the new scroll wheel in the mount.
    • Upon reassembly, be careful to ensure the silver box on the side of the wheel is placed into the frame with the tab facing downward so upon entry into the frame it fits into its slot.
  11. Remove all 5mm screws that connect the circuit board to the main frame with the Phillips head #00.
    • Remove all 5mm screws that connect the circuit board to the main frame with the Phillips head #00.
  12. Place the new motherboard in the mouse. When reassembling the mouse, place the loose plastic piece that holds the scroll wheel and wire in place into the rectangular slots in the circuit board.
    • Place the new motherboard in the mouse.
    • When reassembling the mouse, place the loose plastic piece that holds the scroll wheel and wire in place into the rectangular slots in the circuit board.
Conclusão
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 42
Todo: 615
