Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Peel back the two teflon tape from the top corners and the one larger one from the bottom with a spudger.
Remove the four 7mm screws using a Phillips #00 screwdriver.
Gently remove the top plastic plate of the mouse.
Unplug the white cord from the circuit board.
Lightly pull the two plastic sides of the mouse to remove them.
Using a Phillips #00 screwdriver, remove the 5mm screw holding the scroll wheel in place.
Unplug the cord that connects the scroll wheel to the motherboard.
Gently wiggle the scroll wheel up and back to remove the scroll wheel from the mouse.
Use your thumbs to pop the scroll wheel out from its plastic frame.
Using a Phillips #00 screwdriver, remove all five 5mm screws that connect the motherboard to the main frame.
Place the new motherboard in the mouse.
When reassembling the mouse, place the loose plastic piece that holds the scroll wheel and wire in place into the rectangular slots in the circuit board.
Once the motherboard is removed, pull the wire out of the plastic grooves on the bottom shell.
Then to completely detach the cable, unplug its white connection port from the motherboard.
3 outras pessoas executaram este guia.
