Introdução
Instructions for how to disassemble the top assembly of the Razer Naga Epic mouse.
This is a relatively simple part of the device that houses the middle two buttons of the device as well as being responsible for bridging connections from the numpad to the mainboard.
O que você precisa
The PCB is held to the top panel by...
2 x 6mm Phillips #0 screws towards the front
2 grooves on the top panel holding it in towards the rear
Carefully slide the PCB horizontally away from the grooves on the rear end of the top panel.
