Introdução
How to take apart the assembly where the Razer Naga Epic's numpad and associated components lie.
O que você precisa
The buttons and their PCB are held into the side panel by a retaining bracket.
Unscrew the 4 x 6mm Phillips #0 screws securing the retaining bracket in place.
The retaining bracket is gently clipped in to the side panel.
Gently go round between the retaining bracket and the side panel with a spudger until it comes loose.
You can now separate the retaining bracket.
Gently push the rubber button covers out from the side panel. They are not clipped or held in place by anything.
The button contacts, corresponding PCB, and transparent panel are held together into the retaining bracket by 4 x 6mm Phillips #000 screws.
Unscrew the 4 screws.
Lift the inner retaining bracket away from the PCB bundle.
The transparent panel is threaded through the button contacts and PCB via 4 screw holes.
Using the pointed end of a spudger, gently push the screw holes to push the transparent panel away from the PCB.
You've basically done it all! There might be a bit more you could do with the button contacts and PCB, but that's basically it ^^.
