Ir para o conteúdo principal
Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Maelstrom Wiring Repair
O que você precisa
  1. Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Maelstrom Wiring Repair, Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Maelstrom Wiring Repair: passo 1, imagem 1 %32 Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Maelstrom Wiring Repair, Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Maelstrom Wiring Repair: passo 1, imagem 2 %32 Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Maelstrom Wiring Repair, Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Maelstrom Wiring Repair: passo 1, imagem 3 %32
    • To get to the maelstrom wiring you must first pull off the plastic cover.
    • To do this roll the maelstrom over so the rubber cover on the back is facing up. The rubber pad simply peels off exposing the metal backplate.
    • Then remove the four 8.5mm screws on the back plate of the maelstrom.
  2. Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Maelstrom Wiring Repair: passo 2, imagem 1 %32 Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Maelstrom Wiring Repair: passo 2, imagem 2 %32
    • Once the four screws are removed, the top cover can be lifted off.
    • There is a ribbon wire connecting the volume wheel to the circuit board. This is not permanently attached, and can be plugged back in if it gets pulled out.
    • Remove the three 2mm screws from the circuit board to separate it from the back plate.
  3. Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Maelstrom Wiring Repair: passo 3, imagem 1 %32 Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Maelstrom Wiring Repair: passo 3, imagem 2 %32
    • The circuit board is now completely separate from the housing and the wires can now be inspected.
    • Peel back the tape on the wires to inspect any damage to the wires if there is any.
Conclusão
6 outras pessoas executaram este guia.
Kyle Schober
Membro desde: 02/24/14
640 Reputação
Autoria de 5 guias
Equipe
Michigan Tech, Team 5-8, Lauer Spring 2014 Membro de Michigan Tech, Team 5-8, Lauer Spring 2014
MTU-LAUER-S14S5G8
Membros da 3
Autoria de 13 guias
4 comentários
Well for the last step the wires I peeled the wires by burning them on a gas ranger. Worked Perfectly.
Edwin Lopez - Responder
can you provide the connection map for the cables that go prom remote root to headphones?
johnny1992black - Responder
comeon you wanna tell me you took picture of the cables from one side and the other one not this is a joke right?
muchas gracias por este articulo, es el 2020 y me a servido mucho para arreglar mis audifonos
diego.riquelme.cortes - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 28
Duração total: 5,965
