Ir para o conteúdo principal
Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Ear Cushions Replacement
  1. Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Ear Cushions Replacement, Ear Cushions: passo 1, imagem 1 %32
    • The ear cushions are removed from the device by slightly different methods.
    • To remove the left ear cushion (the side with the boom), rotate the cushion counter clockwise as far as it can turn, then pull the ear cushion straight out from the device.
    • To remove the right ear cushion, rotate it clockwise as far as it can turn, then pull the ear cushion straight out from the device.
  2. Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Ear Cushions Replacement: passo 2, imagem 1 %32
    • In order to remove the cushion from the plastic backing, slide the leather free of the plastic edge, working around the entire cushion until it separates.
Conclusão
Kyle Schober
Membro desde: 02/24/14
640 Reputação
Autoria de 5 guias
Equipe
Michigan Tech, Team 5-8, Lauer Spring 2014 Membro de Michigan Tech, Team 5-8, Lauer Spring 2014
MTU-LAUER-S14S5G8
Membros da 3
Autoria de 13 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 21
Duração total: 1,705
