Ir para o conteúdo principal
Razer Kraken Ultimate Speaker Replacement
O que você precisa
  1. Razer Kraken Ultimate Speaker Replacement, Ear Pads: passo 1, imagem 1 %32 Razer Kraken Ultimate Speaker Replacement, Ear Pads: passo 1, imagem 2 %32 Razer Kraken Ultimate Speaker Replacement, Ear Pads: passo 1, imagem 3 %32
    • Grab the ear piece from one of the sides and lightly pull it outwards.
    • Ideally, do not pull the ear piece directly away from the speaker; it may damage the piece.
  2. Razer Kraken Ultimate Speaker Replacement: passo 2, imagem 1 %32 Razer Kraken Ultimate Speaker Replacement: passo 2, imagem 2 %32
    • Once you have taken off one side, you can then remove the whole piece by slowly prying the pad away from the headphones.
  3. Razer Kraken Ultimate Speaker Replacement: passo 3, imagem 1 %32 Razer Kraken Ultimate Speaker Replacement: passo 3, imagem 2 %32
    • Repeat steps on the other side.
  4. Razer Kraken Ultimate Speaker Replacement, Speaker: passo 4, imagem 1 %32 Razer Kraken Ultimate Speaker Replacement, Speaker: passo 4, imagem 2 %32 Razer Kraken Ultimate Speaker Replacement, Speaker: passo 4, imagem 3 %32
    • Remove the four 10 mm Phillips #00 screws securing the right speaker.
    • Be sure the device is unplugged before attempting to remove any of the screws.
  5. Razer Kraken Ultimate Speaker Replacement: passo 5, imagem 1 %32 Razer Kraken Ultimate Speaker Replacement: passo 5, imagem 2 %32
    • Remove the 10 mm Phillips #00 screws securing the left speaker.
    • Note that one of the screws is hidden behind the product information sticker. Use your screw driver to punch a hole in the sticker.
  6. Razer Kraken Ultimate Speaker Replacement: passo 6, imagem 1 %32 Razer Kraken Ultimate Speaker Replacement: passo 6, imagem 2 %32
    • To fully detach the speakers cut the wires as close as possible to the connection point, leaving plenty of room to solder the new speaker on.
Conclusão
Alex Broggi
Membro desde: 10/24/22
342 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 1-4, Petersen Fall 2022 Membro de UMass Dartmouth, Team 1-4, Petersen Fall 2022
UMASSD-PETERSEN-F22S1G4
Membros da 5
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 38
Duração total: 491
