Ir para o conteúdo principal
Razer Huntsman Tournament Edition Rubber Feet Replacement
O que você precisa
  1. Razer Huntsman Tournament Edition Rubber Feet Replacement, Rubber Feet: passo 1, imagem 1 %32
    • Turn the keyboard upside down such that it it laying on its face.
    • The keys on the keyboard are facing away from you.
  2. Razer Huntsman Tournament Edition Rubber Feet Replacement: passo 2, imagem 1 %32 Razer Huntsman Tournament Edition Rubber Feet Replacement: passo 2, imagem 2 %32 Razer Huntsman Tournament Edition Rubber Feet Replacement: passo 2, imagem 3 %32
    • Use the iFixit Opening Tool or a flat head screwdriver to pry off the rubber feet.
    • Peel the papers off the new rubber feet gently.
    • Before placing the new rubber feet use alcohol to wipe the surrounding area where the new rubber feet are going to be placed.
  3. Razer Huntsman Tournament Edition Rubber Feet Replacement: passo 4, imagem 1 %32
    • Put in replacement rubber feet where the original rubber feet were at.
    • Wait a few minutes for the adhesive to set.
Conclusão
Your keyboard should have replaced rubber feet (or foot if you replaced one).
Ben Altman
Membro desde: 10/25/22
229 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 4-3, Sinclaire Fall 2022 Membro de UMass Dartmouth, Team 4-3, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S4G3
Membros da 5
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 12
Duração total: 240
