Ir para o conteúdo principal
Razer Huntsman Tournament Edition Port Replacement
O que você precisa
  1. Razer Huntsman Tournament Edition Port Replacement, Keycaps: passo 1, imagem 1 %32
    • Place the unplugged keyboard on a flat, clean surface appropriate for working on.
  2. Razer Huntsman Tournament Edition Port Replacement: passo 2, imagem 1 %32 Razer Huntsman Tournament Edition Port Replacement: passo 2, imagem 2 %32
    • Grip the keycap with your keycap puller.
    • You can remove keycaps with your fingers if you don’t have a puller, but the adjacent keycaps must be removed first for sufficient grip.
  3. Razer Huntsman Tournament Edition Port Replacement: passo 3, imagem 1 %32 Razer Huntsman Tournament Edition Port Replacement: passo 3, imagem 2 %32 Razer Huntsman Tournament Edition Port Replacement: passo 3, imagem 3 %32
    • Pull with an upwards force to remove the keycap.
    • Take a moment to clean the area that was previously obscured if it’s dirty.
    • Use gentle force so as not to damage the stabilizers.
  4. Razer Huntsman Tournament Edition Port Replacement, Chassis: passo 4, imagem 1 %32
    • Remove all of the keycaps with a keycap puller.
  5. Razer Huntsman Tournament Edition Port Replacement: passo 5, imagem 1 %32 Razer Huntsman Tournament Edition Port Replacement: passo 5, imagem 2 %32
    • Unscrew the thirteen 6.5 mm screws, using the Phillips #0 screwdriver, that are located in the front panel.
  6. Razer Huntsman Tournament Edition Port Replacement: passo 6, imagem 1 %32
    • Use an opening tool to pry open the chassis.
    • Be careful not to use excessive force during this step so the plastic doesn't warp or break.
  7. Razer Huntsman Tournament Edition Port Replacement: passo 7, imagem 1 %32
    • Gently lift the front panel off.
    • The front panel should be connected to the USB board. Do not tug the panel off as this may damage other parts.
  8. Razer Huntsman Tournament Edition Port Replacement: passo 8, imagem 1 %32
    • Disconnect the internal cable.
  9. Razer Huntsman Tournament Edition Port Replacement, Port: passo 9, imagem 1 %32 Razer Huntsman Tournament Edition Port Replacement, Port: passo 9, imagem 2 %32
    • Unscrew the board with the port.
    • It should be located on the upper left, held in by two 6.5mm Phillips #0 screws.
    • Move the cable out of the way for the second screw
  10. Razer Huntsman Tournament Edition Port Replacement: passo 10, imagem 1 %32
    • Detach the internal cable from the USB board.
    • Do this carefully.
  11. Razer Huntsman Tournament Edition Port Replacement: passo 11, imagem 1 %32
    • Remove the USB board.
Conclusão
Uma outra pessoa concluiu este guia.
Joseph O'Dowd
Membro desde: 10/25/22
383 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 4-3, Sinclaire Fall 2022 Membro de UMass Dartmouth, Team 4-3, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S4G3
Membros da 5
Autoria de 7 guias
Um comentário
how do i get a new port and where
Guardian Suit - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 18
Duração total: 331
