Ir para o conteúdo principal
Razer Huntsman Tournament Edition Key Switch Replacement
O que você precisa
  1. Razer Huntsman Tournament Edition Key Switch Replacement, Keycaps: passo 1, imagem 1 %32
    • Place the unplugged keyboard on a flat, clean surface appropriate for working on.
  2. Razer Huntsman Tournament Edition Key Switch Replacement: passo 2, imagem 1 %32 Razer Huntsman Tournament Edition Key Switch Replacement: passo 2, imagem 2 %32
    • Grip the keycap with your keycap puller.
    • You can remove keycaps with your fingers if you don’t have a puller, but the adjacent keycaps must be removed first for sufficient grip.
  3. Razer Huntsman Tournament Edition Key Switch Replacement: passo 3, imagem 1 %32 Razer Huntsman Tournament Edition Key Switch Replacement: passo 3, imagem 2 %32 Razer Huntsman Tournament Edition Key Switch Replacement: passo 3, imagem 3 %32
    • Pull with an upwards force to remove the keycap.
    • Take a moment to clean the area that was previously obscured if it’s dirty.
    • Use gentle force so as not to damage the stabilizers.
  4. Razer Huntsman Tournament Edition Key Switch Replacement, Chassis: passo 4, imagem 1 %32
    • Remove all of the keycaps with a keycap puller.
  5. Razer Huntsman Tournament Edition Key Switch Replacement: passo 5, imagem 1 %32 Razer Huntsman Tournament Edition Key Switch Replacement: passo 5, imagem 2 %32
    • Unscrew the thirteen 6.5 mm screws, using the Phillips #0 screwdriver, that are located in the front panel.
  6. Razer Huntsman Tournament Edition Key Switch Replacement: passo 6, imagem 1 %32
    • Use an opening tool to pry open the chassis.
    • Be careful not to use excessive force during this step so the plastic doesn't warp or break.
  7. Razer Huntsman Tournament Edition Key Switch Replacement: passo 7, imagem 1 %32
    • Gently lift the front panel off.
    • The front panel should be connected to the USB board. Do not tug the panel off as this may damage other parts.
  8. Razer Huntsman Tournament Edition Key Switch Replacement: passo 8, imagem 1 %32
    • Disconnect the internal cable.
  9. Razer Huntsman Tournament Edition Key Switch Replacement, Key Switch: passo 9, imagem 1 %32 Razer Huntsman Tournament Edition Key Switch Replacement, Key Switch: passo 9, imagem 2 %32
    • Gently push the key switch off of the mainboard with your thumb.
Conclusão
Joseph O'Dowd
Membro desde: 10/25/22
383 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 4-3, Sinclaire Fall 2022 Membro de UMass Dartmouth, Team 4-3, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S4G3
Membros da 5
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 19
Últimos 30 dias: 59
Duração total: 1,285
