Ir para o conteúdo principal
Razer Huntsman TE Keycaps Replacement
O que você precisa
  1. Razer Huntsman TE Keycaps Replacement, Keycaps: passo 1, imagem 1 %32 Razer Huntsman TE Keycaps Replacement, Keycaps: passo 1, imagem 2 %32
    • Identify the correct type of key to replace.
    • Keys such as "Shift" and "Enter" have multiple slots, and each slot has a different shape, so be sure to pick the correct one.
  2. Razer Huntsman TE Keycaps Replacement: passo 2, imagem 1 %32 Razer Huntsman TE Keycaps Replacement: passo 2, imagem 2 %32
    • Insert the keycap puller so that the teeth at the end of the puller sit beneath the keycap.
    • Apply enough upwards force for the keycap to pop out.
  3. Razer Huntsman TE Keycaps Replacement: passo 3, imagem 1 %32 Razer Huntsman TE Keycaps Replacement: passo 3, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Microfiber Cleaning Cloths
    $3.99
    Comprar
    • Apply 91% isopropyl alcohol to microfiber cloth.
    • Wipe around the key.
    • Make sure that there is no residual stickiness on the key.
  4. Razer Huntsman TE Keycaps Replacement: passo 4, imagem 1 %32 Razer Huntsman TE Keycaps Replacement: passo 4, imagem 2 %32
    • Position the replacement keycap above the keyslot.
    • Using your finger, apply downwards force to the keycap until you hear it snap into place.
Conclusão
Use a diagnostic tool such as an online keyboard tester to test the key.
Lucas de Castro
Membro desde: 02/24/21
109 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 37
Duração total: 2,045
