Ir para o conteúdo principal
Razer DeathAdder Chroma USB Cable Replacement
O que você precisa
  1. Razer DeathAdder Chroma USB Cable Replacement, Outer Casing: passo 1, imagem 1 %32
    • Opening the mouse casing will void any warranty that exists for the mouse.
    • Turn the mouse over so the bottom is facing up.
  2. Razer DeathAdder Chroma USB Cable Replacement: passo 2, imagem 1 %32 Razer DeathAdder Chroma USB Cable Replacement: passo 2, imagem 2 %32
    • Use the blunt end of the spudger to pry the adhesive rubber pads from the top left and right edges.
  3. Razer DeathAdder Chroma USB Cable Replacement: passo 3, imagem 1 %32 Razer DeathAdder Chroma USB Cable Replacement: passo 3, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove two 6.7 mm screws.
  4. Razer DeathAdder Chroma USB Cable Replacement: passo 4, imagem 1 %32
    • Use your fingers to identify the location of the screw under the bottom label.
  5. Razer DeathAdder Chroma USB Cable Replacement: passo 5, imagem 1 %32
    • Use a Phillips #0 screwdriver to remove one 6.7 mm screw.
    • Clear the label away from around the screw for easier removal.
  6. Razer DeathAdder Chroma USB Cable Replacement: passo 6, imagem 1 %32 Razer DeathAdder Chroma USB Cable Replacement: passo 6, imagem 2 %32 Razer DeathAdder Chroma USB Cable Replacement: passo 6, imagem 3 %32
    • Turn the mouse over so the bottom is facing down.
    • Separate the top casing from the bottom base by pulling the top casing upwards.
    • Separating the casing too quickly could damage the ribbon connector between the motherboard and the LED lights.
  7. Razer DeathAdder Chroma USB Cable Replacement: passo 7, imagem 1 %32 Razer DeathAdder Chroma USB Cable Replacement: passo 7, imagem 2 %32
    • Disconnect the ribbon connector between the motherboard and the LED lights by pulling upward.
    • Pulling too hard could damage the wire connections.
  8. Razer DeathAdder Chroma USB Cable Replacement, Motherboard: passo 8, imagem 1 %32 Razer DeathAdder Chroma USB Cable Replacement, Motherboard: passo 8, imagem 2 %32
    • Disconnect the ribbon connector between the motherboard and the USB cable by pulling upward.
  9. Razer DeathAdder Chroma USB Cable Replacement: passo 9, imagem 1 %32
    • Use a Phillips #0 screwdriver to remove three 5.5 mm screws.
  10. Razer DeathAdder Chroma USB Cable Replacement: passo 10, imagem 1 %32 Razer DeathAdder Chroma USB Cable Replacement: passo 10, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove two 11.5 mm screws on the side buttons.
  11. Razer DeathAdder Chroma USB Cable Replacement: passo 11, imagem 1 %32
    • Use a Phillips #000 screwdriver to remove one 5.0 mm screw.
  12. Razer DeathAdder Chroma USB Cable Replacement: passo 12, imagem 1 %32 Razer DeathAdder Chroma USB Cable Replacement: passo 12, imagem 2 %32
    • Disconnect the ribbon connector between the motherboard and the optical sensor.
  13. Razer DeathAdder Chroma USB Cable Replacement: passo 13, imagem 1 %32 Razer DeathAdder Chroma USB Cable Replacement: passo 13, imagem 2 %32
    • Remove the motherboard by grasping the sides and gently pulling upward.
  14. Razer DeathAdder Chroma USB Cable Replacement, USB Cable: passo 14, imagem 1 %32
    • Locate the USB cable.
  15. Razer DeathAdder Chroma USB Cable Replacement: passo 15, imagem 1 %32 Razer DeathAdder Chroma USB Cable Replacement: passo 15, imagem 2 %32
    • Remove the USB cable by pulling it up and out.
Conclusão
7 outras pessoas executaram este guia.
Henry Shi
Membro desde: 03/26/17
221 Reputação
Autoria de 1 guia
Equipe
Baylor, Team S5-G2, Williams Spring 2017 Membro de Baylor, Team S5-G2, Williams Spring 2017
BU-WILLIAMS-S17S5G2
Membros da 3
Autoria de 6 guias
5 comentários
Thank you! It realy worked. Btw: The cable for the Deathadder 2013 is working for the Chroma and Elite as well. I Just tried it :)
Pokefreeks - Responder
Thanks for the advice
João Costa Santos -
Great and easy guide thanx alot, saved me a new mouse :)
jesperkb - Responder
Is there a reliable website where I can get a replacement cable with low delivery time?
Bubbles EXE - Responder
where can i get the cable from?
Mourya Singham - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 18
Últimos 30 dias: 44
Duração total: 14,377
