Introdução
This guide outlines how to replace the SSD on your Razor Blade Stealth if it damaged or non-functional. If the computer presents a blank screen and does not boot up, the SSD may be damaged. If you want to increase the SSD storage on the computer, swap the SSD using this guide. Some iFixit tools are required for this replacement.
O que você precisa
Use a Torx T5 screwdriver to remove the eight, 3mm screws on the bottom cover of the laptop.
