Ir para o conteúdo principal
Razer Blade Stealth 2017 Motherboard Replacement
O que você precisa
  1. Razer Blade Stealth 2017 Motherboard Replacement, Battery: passo 1, imagem 1 %32 Razer Blade Stealth 2017 Motherboard Replacement, Battery: passo 1, imagem 2 %32
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Use a Torx T5 screwdriver to remove the eight, 3mm screws on the bottom cover of the laptop.
    • Whenever you remove screws from the device, remember to save and label them.
  2. Razer Blade Stealth 2017 Motherboard Replacement: passo 2, imagem 1 %32
    • Remove the bottom cover of the laptop by sliding it away from the hinge.
    • Do not force the cover up!
  3. Razer Blade Stealth 2017 Motherboard Replacement: passo 3, imagem 1 %32 Razer Blade Stealth 2017 Motherboard Replacement: passo 3, imagem 2 %32
    • Use your fingernail to pry up and disconnect the battery from the motherboard.
  4. Razer Blade Stealth 2017 Motherboard Replacement: passo 4, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove the six, 5mm screws securing the battery.
  5. Razer Blade Stealth 2017 Motherboard Replacement: passo 5, imagem 1 %32 Razer Blade Stealth 2017 Motherboard Replacement: passo 5, imagem 2 %32
    • Remove any tape attached to the battery.
    • Use the plastic spudger to pry out the battery.
  6. Razer Blade Stealth 2017 Motherboard Replacement, Fan: passo 6, imagem 1 %32 Razer Blade Stealth 2017 Motherboard Replacement, Fan: passo 6, imagem 2 %32
    • Use a plastic spudger to lift the white clasp on the fan connector.
  7. Razer Blade Stealth 2017 Motherboard Replacement: passo 7, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use tweezers to pull the fan cable out of the opened connector terminal.
  8. Razer Blade Stealth 2017 Motherboard Replacement: passo 8, imagem 1 %32 Razer Blade Stealth 2017 Motherboard Replacement: passo 8, imagem 2 %32 Razer Blade Stealth 2017 Motherboard Replacement: passo 8, imagem 3 %32
    • Use tweezers to squeeze the fan's white header.
    • Disconnect the fan connector by sliding it out toward the rear of the chassis.
  9. Razer Blade Stealth 2017 Motherboard Replacement: passo 9, imagem 1 %32 Razer Blade Stealth 2017 Motherboard Replacement: passo 9, imagem 2 %32 Razer Blade Stealth 2017 Motherboard Replacement: passo 9, imagem 3 %32
    • Remove any tape attached to the fans.
    • Use a Phillips #00 screwdriver to remove the six, 3mm screws and the metal bracket around both fans.
  10. Razer Blade Stealth 2017 Motherboard Replacement: passo 10, imagem 1 %32 Razer Blade Stealth 2017 Motherboard Replacement: passo 10, imagem 2 %32
    • Use a plastic spudger to slide the fans out of the case.
  11. Razer Blade Stealth 2017 Motherboard Replacement, Motherboard: passo 11, imagem 1 %32 Razer Blade Stealth 2017 Motherboard Replacement, Motherboard: passo 11, imagem 2 %32 Razer Blade Stealth 2017 Motherboard Replacement, Motherboard: passo 11, imagem 3 %32
    • Use a plastic spudger to gently undo the connections to the motherboard.
  12. Razer Blade Stealth 2017 Motherboard Replacement: passo 12, imagem 1 %32 Razer Blade Stealth 2017 Motherboard Replacement: passo 12, imagem 2 %32 Razer Blade Stealth 2017 Motherboard Replacement: passo 12, imagem 3 %32
    • Use a Phillips #00 screwdriver to remove the six 4 mm screws holding the display hinges on both side.
    • Remove the small plastic brackets holding the display hinges.
  13. Razer Blade Stealth 2017 Motherboard Replacement: passo 13, imagem 1 %32
    • Remove the 2.6 mm screw holding the Wi-Fi card down with a Phillips #00 screwdriver.
    • Remove the motherboard from the laptop.
Conclusão
To reassemble your device, follow these instructions in reverse order. Ensure that your laptop boots into BIOS for any necessary configuration after installing a new motherboard.
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 50
