Ir para o conteúdo principal
Razer Blade Stealth 2017 Fan Replacement
O que você precisa
  1. Razer Blade Stealth 2017 Fan Replacement, Battery: passo 1, imagem 1 %32 Razer Blade Stealth 2017 Fan Replacement, Battery: passo 1, imagem 2 %32
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Use a Torx T5 screwdriver to remove the eight, 3mm screws on the bottom cover of the laptop.
    • Whenever you remove screws from the device, remember to save and label them.
  2. Razer Blade Stealth 2017 Fan Replacement: passo 2, imagem 1 %32
    • Remove the bottom cover of the laptop by sliding it away from the hinge.
    • Do not force the cover up!
  3. Razer Blade Stealth 2017 Fan Replacement: passo 3, imagem 1 %32 Razer Blade Stealth 2017 Fan Replacement: passo 3, imagem 2 %32
    • Use your fingernail to pry up and disconnect the battery from the motherboard.
  4. Razer Blade Stealth 2017 Fan Replacement: passo 4, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove the six, 5mm screws securing the battery.
  5. Razer Blade Stealth 2017 Fan Replacement: passo 5, imagem 1 %32 Razer Blade Stealth 2017 Fan Replacement: passo 5, imagem 2 %32
    • Remove any tape attached to the battery.
    • Use the plastic spudger to pry out the battery.
  6. Razer Blade Stealth 2017 Fan Replacement, Fan: passo 6, imagem 1 %32 Razer Blade Stealth 2017 Fan Replacement, Fan: passo 6, imagem 2 %32
    • Use a plastic spudger to lift the white clasp on the fan connector.
  7. Razer Blade Stealth 2017 Fan Replacement: passo 7, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use tweezers to pull the fan cable out of the opened connector terminal.
  8. Razer Blade Stealth 2017 Fan Replacement: passo 8, imagem 1 %32 Razer Blade Stealth 2017 Fan Replacement: passo 8, imagem 2 %32 Razer Blade Stealth 2017 Fan Replacement: passo 8, imagem 3 %32
    • Use tweezers to squeeze the fan's white header.
    • Disconnect the fan connector by sliding it out toward the rear of the chassis.
  9. Razer Blade Stealth 2017 Fan Replacement: passo 9, imagem 1 %32 Razer Blade Stealth 2017 Fan Replacement: passo 9, imagem 2 %32 Razer Blade Stealth 2017 Fan Replacement: passo 9, imagem 3 %32
    • Remove any tape attached to the fans.
    • Use a Phillips #00 screwdriver to remove the six, 3mm screws and the metal bracket around both fans.
  10. Razer Blade Stealth 2017 Fan Replacement: passo 10, imagem 1 %32 Razer Blade Stealth 2017 Fan Replacement: passo 10, imagem 2 %32
    • Use a plastic spudger to slide the fans out of the case.
Conclusão
Helene Willits
Membro desde: 10/10/19
765 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team S11-G3, Regan Fall 2019 Membro de Cal Poly, Team S11-G3, Regan Fall 2019
CPSU-REGAN-F19S11G3
Membros da 4
Autoria de 7 guias
Um comentário
What is the part number for the black fan? I'm trying to buy a replacement but I can't find any :(
Sang Jae Kouwenberg - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 32
Duração total: 2,265
