Ir para o conteúdo principal
Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement
O que você precisa
  1. Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement, Battery: passo 1, imagem 1 %32 Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement, Battery: passo 1, imagem 2 %32 Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement, Battery: passo 1, imagem 3 %32
    • Use a Torx screwdriver to remove the eight 3 mm screws on the back case.
    • Remove the rear cover by prying up lightly starting in one of the corners.
  2. Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement: passo 2, imagem 1 %32 Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement: passo 2, imagem 2 %32
    • Use a Phillips screwdriver to remove the six screws securing the battery.
  3. Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement: passo 3, imagem 1 %32
    • Unplug the battery connector from the motherboard.
    • Remove the battery from the device.
  4. Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement, Killer 1535 Wireless Card: passo 4, imagem 1 %32 Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement, Killer 1535 Wireless Card: passo 4, imagem 2 %32 Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement, Killer 1535 Wireless Card: passo 4, imagem 3 %32
    • Carefully remove the auxiliary and main wire from the Killer 1535 wireless card.
  5. Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement: passo 5, imagem 1 %32 Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement: passo 5, imagem 2 %32 Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement: passo 5, imagem 3 %32
    • Use a Phillips #00 screwdriver to remove the two 2.61 mm screw holding the card in place.
  6. Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement: passo 6, imagem 1 %32 Razer Blade Stealth 2016 Killer 1535 Wireless Card Replacement: passo 6, imagem 2 %32
    • Carefully remove the card.
Conclusão
Kaitlyn Murray
Membro desde: 10/10/19
239 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team S1-G4, Leahy Fall 2019 Membro de USF Tampa, Team S1-G4, Leahy Fall 2019
USFT-LEAHY-F19S1G4
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 17
Duração total: 961
