Ir para o conteúdo principal
Razer Blade Stealth 2016 Keyboard Replacement
O que você precisa
  1. Razer Blade Stealth 2016 Keyboard Replacement, Battery: passo 1, imagem 1 %32 Razer Blade Stealth 2016 Keyboard Replacement, Battery: passo 1, imagem 2 %32 Razer Blade Stealth 2016 Keyboard Replacement, Battery: passo 1, imagem 3 %32
    • Use a Torx screwdriver to remove the eight 3 mm screws on the back case.
    • Remove the rear cover by prying up lightly starting in one of the corners.
  2. Razer Blade Stealth 2016 Keyboard Replacement: passo 2, imagem 1 %32 Razer Blade Stealth 2016 Keyboard Replacement: passo 2, imagem 2 %32
    • Use a Phillips screwdriver to remove the six screws securing the battery.
  3. Razer Blade Stealth 2016 Keyboard Replacement: passo 3, imagem 1 %32
    • Unplug the battery connector from the motherboard.
    • Remove the battery from the device.
  4. Razer Blade Stealth 2016 Keyboard Replacement, Motherboard: passo 4, imagem 1 %32
    • Remove the red and black cables that are attached to the motherboard.
  5. Razer Blade Stealth 2016 Keyboard Replacement: passo 5, imagem 1 %32
    • Remove the four 3.4 mm screws around the black square using a T4 Torx screwdriver.
    • Remove the heatsink.
  6. Razer Blade Stealth 2016 Keyboard Replacement: passo 6, imagem 1 %32
    • Remove the 3.4 mm screws to the cooling fans using a T4 Torx screwdriver.
    • Remove the cooling fans.
  7. Razer Blade Stealth 2016 Keyboard Replacement: passo 7, imagem 1 %32 Razer Blade Stealth 2016 Keyboard Replacement: passo 7, imagem 2 %32 Razer Blade Stealth 2016 Keyboard Replacement: passo 7, imagem 3 %32
    • Remove the 3.4 mm screws on the perimeter of the motherboard using a T4 Torx screwdriver.
  8. Razer Blade Stealth 2016 Keyboard Replacement: passo 8, imagem 1 %32
    • Remove the motherboard.
  9. Razer Blade Stealth 2016 Keyboard Replacement, Keyboard: passo 9, imagem 1 %32 Razer Blade Stealth 2016 Keyboard Replacement, Keyboard: passo 9, imagem 2 %32 Razer Blade Stealth 2016 Keyboard Replacement, Keyboard: passo 9, imagem 3 %32
    • Flip all white tabs up to unlock three ZIF connectors using the opening tool.
    • Flip all black tabs up to unlock the three ZIF connectors using the opening tool.
    • This is how the tabs look in the flipped up position.
  10. Razer Blade Stealth 2016 Keyboard Replacement: passo 10, imagem 1 %32 Razer Blade Stealth 2016 Keyboard Replacement: passo 10, imagem 2 %32 Razer Blade Stealth 2016 Keyboard Replacement: passo 10, imagem 3 %32
    • Pull the cables out gently.
  11. Razer Blade Stealth 2016 Keyboard Replacement: passo 11, imagem 1 %32 Razer Blade Stealth 2016 Keyboard Replacement: passo 11, imagem 2 %32 Razer Blade Stealth 2016 Keyboard Replacement: passo 11, imagem 3 %32
    • Remove fifty-five 3.4 mm keyboard screws with the T5 Torx screwdriver.
    • 5 screw locations are highlighted but locate all 55 screws and remove them.
  12. Razer Blade Stealth 2016 Keyboard Replacement: passo 12, imagem 1 %32 Razer Blade Stealth 2016 Keyboard Replacement: passo 12, imagem 2 %32 Razer Blade Stealth 2016 Keyboard Replacement: passo 12, imagem 3 %32
    • Remove the keyboard from the laptop.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 37
Duração total: 841
