Ir para o conteúdo principal
Razer Blade Stealth 2016 Heat Sink Replacement
O que você precisa
  1. Razer Blade Stealth 2016 Heat Sink Replacement, Battery: passo 1, imagem 1 %32 Razer Blade Stealth 2016 Heat Sink Replacement, Battery: passo 1, imagem 2 %32 Razer Blade Stealth 2016 Heat Sink Replacement, Battery: passo 1, imagem 3 %32
    • Use a Torx screwdriver to remove the eight 3 mm screws on the back case.
    • Remove the rear cover by prying up lightly starting in one of the corners.
  2. Razer Blade Stealth 2016 Heat Sink Replacement: passo 2, imagem 1 %32 Razer Blade Stealth 2016 Heat Sink Replacement: passo 2, imagem 2 %32
    • Use a Phillips screwdriver to remove the six screws securing the battery.
  3. Razer Blade Stealth 2016 Heat Sink Replacement: passo 3, imagem 1 %32
    • Unplug the battery connector from the motherboard.
    • Remove the battery from the device.
  4. Razer Blade Stealth 2016 Heat Sink Replacement, Fans: passo 4, imagem 1 %32 Razer Blade Stealth 2016 Heat Sink Replacement, Fans: passo 4, imagem 2 %32
    • Remove the three 3.38 mm screws from the left fan (this fan should be black).
  5. Razer Blade Stealth 2016 Heat Sink Replacement: passo 5, imagem 1 %32
    • Carefully lift and remove the left fan.
  6. Razer Blade Stealth 2016 Heat Sink Replacement: passo 6, imagem 1 %32 Razer Blade Stealth 2016 Heat Sink Replacement: passo 6, imagem 2 %32 Razer Blade Stealth 2016 Heat Sink Replacement: passo 6, imagem 3 %32
    • Repeat steps five and six to remove the silver, right fan.
  7. Razer Blade Stealth 2016 Heat Sink Replacement, Heat Sink: passo 7, imagem 1 %32 Razer Blade Stealth 2016 Heat Sink Replacement, Heat Sink: passo 7, imagem 2 %32
    • Remove the four 3.38 mm screws around the black square using a Phillips #00 screwdriver.
  8. Razer Blade Stealth 2016 Heat Sink Replacement: passo 8, imagem 1 %32 Razer Blade Stealth 2016 Heat Sink Replacement: passo 8, imagem 2 %32 Razer Blade Stealth 2016 Heat Sink Replacement: passo 8, imagem 3 %32
    • Once the screws are removed, the piece can be gently lifted from the back of the device.
Conclusão
Uma outra pessoa concluiu este guia.
Lindsay Grant
Membro desde: 10/10/19
403 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team S1-G4, Leahy Fall 2019 Membro de USF Tampa, Team S1-G4, Leahy Fall 2019
USFT-LEAHY-F19S1G4
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 17
Duração total: 1,326
