Ir para o conteúdo principal
Razer Blade Stealth 2016 Hard Drive Replacement
O que você precisa
  1. Razer Blade Stealth 2016 Hard Drive Replacement, Hard Drive: passo 1, imagem 1 %32
    • Turn the laptop upside down!
  2. Razer Blade Stealth 2016 Hard Drive Replacement: passo 2, imagem 1 %32
    • There are 10 screws in total, they can be found at the red circles shown in the picture!
    • NOTE : you need to use a T5 screwdriver!
  3. Razer Blade Stealth 2016 Hard Drive Replacement: passo 3, imagem 1 %32
    • The hard drive is located under the fan on the left side as shown in the picture!
  4. Razer Blade Stealth 2016 Hard Drive Replacement: passo 4, imagem 1 %32
    • The hard drive is located under the fan on the left side.
    • Slowly peel back the silver piece and black tape beneath it to reveal the hard drive.
  5. Razer Blade Stealth 2016 Hard Drive Replacement: passo 5, imagem 1 %32 Razer Blade Stealth 2016 Hard Drive Replacement: passo 5, imagem 2 %32
    • Using a Phillips screwdriver, remove the 2.5 mm screw on the left side of the hard drive.
    • After you unscrew the hard drive, it will pop out by itself
    • The Phillips screw driver is included in the kit that was provided on step 2!
  6. Razer Blade Stealth 2016 Hard Drive Replacement: passo 6, imagem 1 %32 Razer Blade Stealth 2016 Hard Drive Replacement: passo 6, imagem 2 %32
    • Carefully slide the hard drive out from its slot.
Conclusão
Uma outra pessoa concluiu este guia.
Lindsay Grant
Membro desde: 10/10/19
403 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team S1-G4, Leahy Fall 2019 Membro de USF Tampa, Team S1-G4, Leahy Fall 2019
USFT-LEAHY-F19S1G4
4 Membros
Autoria de 5 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 38
Ao todo: 3,034
