Ir para o conteúdo principal
Razer Blade RZ09-0130 2015 Trackpad Button Replacement
O que você precisa
  1. Razer Blade RZ09-0130 2015 Trackpad Button Replacement, Back Panel: passo 1, imagem 1 %32 Razer Blade RZ09-0130 2015 Trackpad Button Replacement, Back Panel: passo 1, imagem 2 %32
    • Be sure to power off the device before beginning.
    • Use a Torx T5 screwdriver to remove the ten 3 mm screws along the edge of the back panel.
  2. Razer Blade RZ09-0130 2015 Trackpad Button Replacement: passo 2, imagem 1 %32 Razer Blade RZ09-0130 2015 Trackpad Button Replacement: passo 2, imagem 2 %32
    • Remove the back panel from the laptop by sliding it away from the hinge.
    • This device is missing the battery. Make sure to detach the battery connector before proceeding with laptop repairs.
  3. Razer Blade RZ09-0130 2015 Trackpad Button Replacement, Trackpad Button: passo 3, imagem 1 %32 Razer Blade RZ09-0130 2015 Trackpad Button Replacement, Trackpad Button: passo 3, imagem 2 %32 Razer Blade RZ09-0130 2015 Trackpad Button Replacement, Trackpad Button: passo 3, imagem 3 %32
    • Detach the two connectors from the motherboard by gently pulling them directly out of their ports with your fingers.
  4. Razer Blade RZ09-0130 2015 Trackpad Button Replacement: passo 4, imagem 1 %32 Razer Blade RZ09-0130 2015 Trackpad Button Replacement: passo 4, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove the two 3 mm screws holding the trackpad's circuit board to the chassis.
  5. Razer Blade RZ09-0130 2015 Trackpad Button Replacement: passo 5, imagem 1 %32
    • Remove the trackpad circuit board by holding one end and gently lifting it upwards.
Conclusão
Carson Kellerman
Membro desde: 01/29/20
495 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team S18-G1, White Winter 2020 Membro de Cal Poly, Team S18-G1, White Winter 2020
CPSU-WHITE-W20S18G1
Membros da 4
Autoria de 6 guias
Um comentário
Looking for that small ribbon cable, very hard to find, any clues?
serpentexotics - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 26
Duração total: 2,172
