Ir para o conteúdo principal
Razer Blade RZ09-0130 2015 Fan Replacement
O que você precisa
  1. Razer Blade RZ09-0130 2015 Fan Replacement, Back Panel: passo 1, imagem 1 %32 Razer Blade RZ09-0130 2015 Fan Replacement, Back Panel: passo 1, imagem 2 %32
    • Be sure to power off the device before beginning.
    • Use a Torx T5 screwdriver to remove the ten 3 mm screws along the edge of the back panel.
  2. Razer Blade RZ09-0130 2015 Fan Replacement: passo 2, imagem 1 %32 Razer Blade RZ09-0130 2015 Fan Replacement: passo 2, imagem 2 %32
    • Remove the back panel from the laptop by sliding it away from the hinge.
    • This device is missing the battery. Make sure to detach the battery connector before proceeding with laptop repairs.
  3. Razer Blade RZ09-0130 2015 Fan Replacement, Fan: passo 3, imagem 1 %32 Razer Blade RZ09-0130 2015 Fan Replacement, Fan: passo 3, imagem 2 %32
    • Remove the three screw caps by pulling them upward with your fingers.
  4. Razer Blade RZ09-0130 2015 Fan Replacement: passo 4, imagem 1 %32
    • Remove the three 3mm Phillips #0 screws.
  5. Razer Blade RZ09-0130 2015 Fan Replacement: passo 5, imagem 1 %32 Razer Blade RZ09-0130 2015 Fan Replacement: passo 5, imagem 2 %32
    • Peel back the two adhesive strips from the fan until they are removed.
  6. Razer Blade RZ09-0130 2015 Fan Replacement: passo 6, imagem 1 %32 Razer Blade RZ09-0130 2015 Fan Replacement: passo 6, imagem 2 %32 Razer Blade RZ09-0130 2015 Fan Replacement: passo 6, imagem 3 %32
    • Remove the connector by pulling it away from the motherboard with your fingers.
  7. Razer Blade RZ09-0130 2015 Fan Replacement: passo 7, imagem 1 %32
    • Holding the rounded edge of the fan, slowly lift upwards until it is removed.
  8. Razer Blade RZ09-0130 2015 Fan Replacement: passo 8, imagem 1 %32
    • Repeat the preceding steps to remove the second fan.
Conclusão
Tyler Clayton
Membro desde: 01/22/20
183 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S18-G1, White Winter 2020 Membro de Cal Poly, Team S18-G1, White Winter 2020
CPSU-WHITE-W20S18G1
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 17
Duração total: 614
