Ir para o conteúdo principal
Razer Blade RZ09-0102 Motherboard Replacement
O que você precisa
  1. Razer Blade RZ09-0102 Motherboard Replacement, Rear Panel: passo 1, imagem 1 %32
    • Before you begin, be sure to turn off your laptop.
    • Using a Torx T5 screwdriver, remove the ten 1/8 inch screws securing the back cover.
    • Remove the back cover.
  2. Razer Blade RZ09-0102 Motherboard Replacement, Battery: passo 2, imagem 1 %32 Razer Blade RZ09-0102 Motherboard Replacement, Battery: passo 2, imagem 2 %32
    • Remove the seven screws holding the battery in place using a Phillips #0 screwdriver.
  3. Razer Blade RZ09-0102 Motherboard Replacement: passo 3, imagem 1 %32
    • Unlock the ZIF connectors securing the right ribbon cable.
    • To unlock a ZIF connector, use an opening tool or your fingernail to flip up the small, hinged locking flap.
    • Carefully pull the two ribbon cables out of their sockets.
  4. Razer Blade RZ09-0102 Motherboard Replacement: passo 4, imagem 1 %32
    • Use an opening tool to unlock the ZIF connector securing the white ribbon over the battery.
  5. Razer Blade RZ09-0102 Motherboard Replacement: passo 5, imagem 1 %32 Razer Blade RZ09-0102 Motherboard Replacement: passo 5, imagem 2 %32
    • Carefully pull out the two connectors out of their sockets.
    • Pull parallel to the motherboard, not straight up.
  6. Razer Blade RZ09-0102 Motherboard Replacement: passo 6, imagem 1 %32 Razer Blade RZ09-0102 Motherboard Replacement: passo 6, imagem 2 %32
    • Pull the wide battery connector towards the battery to disconnect it from the motherboard.
  7. Razer Blade RZ09-0102 Motherboard Replacement: passo 7, imagem 1 %32 Razer Blade RZ09-0102 Motherboard Replacement: passo 7, imagem 2 %32
    • Remove the battery from the laptop.
  8. Razer Blade RZ09-0102 Motherboard Replacement, Speakers: passo 8, imagem 1 %32 Razer Blade RZ09-0102 Motherboard Replacement, Speakers: passo 8, imagem 2 %32
    • Using a Phillips #0 screwdriver, remove the two screws holding down the speaker.
  9. Razer Blade RZ09-0102 Motherboard Replacement: passo 9, imagem 1 %32
    • Disconnect the wire by pinching with your fingers and pulling up.
  10. Razer Blade RZ09-0102 Motherboard Replacement: passo 10, imagem 1 %32
    • Remove the speaker.
  11. Razer Blade RZ09-0102 Motherboard Replacement, Fan: passo 11, imagem 1 %32
    • Remove the three black rubber pads that cover the screws holding the fan.
  12. Razer Blade RZ09-0102 Motherboard Replacement: passo 12, imagem 1 %32
    • Use the Phillips #0 screwdriver to remove the three 1/4 inch screws.
  13. Razer Blade RZ09-0102 Motherboard Replacement: passo 13, imagem 1 %32
    • Disconnect the wire that goes from the fan into the white connector, but leave the wire attached to the fan.
  14. Razer Blade RZ09-0102 Motherboard Replacement: passo 14, imagem 1 %32 Razer Blade RZ09-0102 Motherboard Replacement: passo 14, imagem 2 %32
    • Lift the fan out with your hands.
  15. Razer Blade RZ09-0102 Motherboard Replacement, Motherboard: passo 15, imagem 1 %32
    • On the left and right sides of the motherboard, remove the black tape holding down the wires.
  16. Razer Blade RZ09-0102 Motherboard Replacement: passo 16, imagem 1 %32
    • Using a Phillips #0 screwdriver, remove the single 4.5mm long screw holding down the network card.
  17. Razer Blade RZ09-0102 Motherboard Replacement: passo 17, imagem 1 %32
    • Pull out the network card from its connector on the motherboard.
  18. Razer Blade RZ09-0102 Motherboard Replacement: passo 18, imagem 1 %32 Razer Blade RZ09-0102 Motherboard Replacement: passo 18, imagem 2 %32 Razer Blade RZ09-0102 Motherboard Replacement: passo 18, imagem 3 %32
    • Disconnect the 2 wires on right side and the 1 wire on the left that holds the motherboard down. To remove the two right wires pull them straight out of their connectors. To remove the left wire pull up on the metal clamp and pull the wire straight out.
  19. Razer Blade RZ09-0102 Motherboard Replacement: passo 19, imagem 1 %32 Razer Blade RZ09-0102 Motherboard Replacement: passo 19, imagem 2 %32
    • Remove the wire located close to left hand side black ribbon cable. Pull down on both sides of the connector to remove.
  20. Razer Blade RZ09-0102 Motherboard Replacement: passo 20, imagem 1 %32
    • Using a Phillips #0 screwdriver, remove the nine 5 mm screws holding down the motherboard to the laptop case.
  21. Razer Blade RZ09-0102 Motherboard Replacement: passo 21, imagem 1 %32
    • Lift the motherboard straight up out of case.
Conclusão
5 outras pessoas executaram este guia.
2 comentários
I broke my white ribbon, where do I get a replacement? Anyone please help! Thank you!!!
ksm270 - Responder
Where can I purchase the motherboard, I am trying to replace mine and cannot find the part anywhere other than eBay.
rmasesg - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 28
Duração total: 5,428
