Ir para o conteúdo principal
Razer Blade 14" (2013) Battery Replacement
O que você precisa
  1. Razer Blade 14" (2013) Battery Replacement, Remove the back cover: passo 1, imagem 1 %32 Razer Blade 14" (2013) Battery Replacement, Remove the back cover: passo 1, imagem 2 %32
    • Remove all 10 Torx T5 Screws
  2. Razer Blade 14" (2013) Battery Replacement, Disconnect the keyboard cables: passo 2, imagem 1 %32 Razer Blade 14" (2013) Battery Replacement, Disconnect the keyboard cables: passo 2, imagem 2 %32 Razer Blade 14" (2013) Battery Replacement, Disconnect the keyboard cables: passo 2, imagem 3 %32
    • Flip the hold down up
    • Remove the cable
    • Repeat for second cable
  3. Razer Blade 14" (2013) Battery Replacement, Remove Touchpad cable: passo 3, imagem 1 %32 Razer Blade 14" (2013) Battery Replacement, Remove Touchpad cable: passo 3, imagem 2 %32 Razer Blade 14" (2013) Battery Replacement, Remove Touchpad cable: passo 3, imagem 3 %32
    • Unclip hold-down
    • Remove cable
  4. Razer Blade 14" (2013) Battery Replacement, Disconnect Battery: passo 4, imagem 1 %32 Razer Blade 14" (2013) Battery Replacement, Disconnect Battery: passo 4, imagem 2 %32 Razer Blade 14" (2013) Battery Replacement, Disconnect Battery: passo 4, imagem 3 %32
    • Use a spudger to disconnect the plug from the connector by pulling it away from the socket, parallel to the board.
    • Bend the connector backwards to prevent it from getting in the way of the motherboard.
  5. Razer Blade 14" (2013) Battery Replacement, Remove Battery Screws: passo 5, imagem 1 %32 Razer Blade 14" (2013) Battery Replacement, Remove Battery Screws: passo 5, imagem 2 %32
    • Remove the 7 battery screws
  6. Razer Blade 14" (2013) Battery Replacement, Remove the Battery: passo 6, imagem 1 %32 Razer Blade 14" (2013) Battery Replacement, Remove the Battery: passo 6, imagem 2 %32
    • Remove the battery by pulling up from the side closest to the motherboard
    • Be careful of the other cables and the battery cable
    • You will have to lift up just a bit, then slide forward to clear one cable and the back cover screws
Conclusão
21 outras pessoas executaram este guia.
tallme15
Membro desde: 03/09/13
902 Reputação
Autoria de 2 guias
17 comentários
i want buy a battery for razer blade but I can't buy it anywhere
Please help me, my battery only 20% heathly
dinhphucloctmx - Responder
It seems that the only way to get the battery replaced is to send the laptop to Razer directly. According to others it costs about $200 plus shipping and so on. Unless you find something on eBay or that sort of thing.
tallme15 -
May I have a detailed guide on how you remove the cable over the battery, please? I am not used to taking machines apart, and wouldn't want to risk ruining my laptop. (didn't quite understand your pictures)
ceci - Responder
The only way to remove the cable is to work it out with a set of tweezers and be gentle not to pull the cables lose from the connector.
Samer Sultan -
Thank you for these instructions, it was very helpful, the only problem is now that the new battery has been installed, it will only charge to 73% and while its still plugged in the battery will drain down to 0%, is there a fix for this problem?
Jay - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 17
Duração total: 28,114
