Ir para o conteúdo principal
Razer Blackwidow Tournament Edition Chroma Front Panel Replacement
O que você precisa
  1. Razer Blackwidow Tournament Edition Chroma Front Panel Replacement, Rubber Feet: passo 1, imagem 1 %32 Razer Blackwidow Tournament Edition Chroma Front Panel Replacement, Rubber Feet: passo 1, imagem 2 %32
    • Turn the keyboard over so that it is lying flat on its face.
    • Use the iFixit opening tool to pry the rubber feet off the keyboard.
  2. Razer Blackwidow Tournament Edition Chroma Front Panel Replacement, Front Panel: passo 2, imagem 1 %32 Razer Blackwidow Tournament Edition Chroma Front Panel Replacement, Front Panel: passo 2, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove the six screws on the back of the keyboard.
    • Use an opening tool as a wedge between the front and back panel to pry open the front panel.
    • If the front and back panel won't separate, DO NOT use excessive force. This may result in damaging the keyboard.
    • Instead, slide the opening tool across the keyboard in between the front and back panel. Go around the edges of the keyboard until the panels disconnect.
    • Flip the keyboard over so the keys are facing up.
    • Grabbing the left and right lips of the front panel, lift both ends up, removing the front panel.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 19
Duração total: 1,254
