Introdução
In this replacement guide we will go over how to disassemble the Razer BlackWidow Chroma. After disassembling the keyboard there will be a link on how to solder and replace the lights.
O que você precisa
Gently pull off the four rubber tabs located on the corners of the keyboard with your fingers.
Click the link below to watch a video that will guide you through the rest of the steps on how to replace LEDs in the keyboard. This step does require soldering . How to Replace Back-light LEDs
3 outras pessoas executaram este guia.
2 comentários
High brightness led’s, 3mm.
