Ir para o conteúdo principal
Razer BlackWidow Chroma Key Replacement
O que você precisa
  1. Razer BlackWidow Chroma Key Replacement, Key: passo 1, imagem 1 %32
    • If the problematic key is still attached, place the edge of the medium blue pry tool under the key. Then gently pry up until key is detached.
  2. Razer BlackWidow Chroma Key Replacement: passo 2, imagem 1 %32
    • Some larger keys may also be held in by two small metal hooks. To separate them gently slide the key left to separate right hook, then to the right to separate the left hook. Be careful not to break the mounting holes on the key itself.
Conclusão
7 outras pessoas executaram este guia.
Kirk Foreman
Membro desde: 02/01/17
248 Reputação
Autoria de 1 guia
Equipe
UW Tacoma, Team 2-6, Rose Winter 2017 Membro de UW Tacoma, Team 2-6, Rose Winter 2017
UWT-ROSE-W17S2G6
Membros da 3
Autoria de 3 guias
3 comentários
This has absolutely nothing to do with fixing a stuck key. Useless information.
Kyle - Responder
99% of steps to replace a key is missing. What a joke.
Jacinto - Responder
please change the name to “keycap” I don’t see this as useless but, misleading.
Shaun Conklin - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 78
Duração total: 12,703
