Introdução
This guide will show you how to remove and replace the back panel of the Razer BlackWidow Chroma keyboard when it is broken or non-functional.
O que você precisa
Turn the keyboard over so that it is lying flat on its face.
Use the iFixit opening tool to pry the rubber feet off the keyboard.
Use a Phillips #1 screwdriver to remove the six screws on the back of the keyboard.
Use an opening tool as a wedge between the front and back panel to pry open the front panel.
Instead, slide the opening tool across the keyboard in between the front and back panel. Go around the edges of the keyboard until the panels disconnect.
Flip the keyboard over so the keys are facing up.
Grabbing the left and right lips of the front panel, lift both ends up, removing the front panel.
Using a Phillips #1 screwdriver, remove all ten screws found along the outer edges of the keyboard.
Uma outra pessoa concluiu este guia.
Um comentário
Lacks details on where the clips are. It resulted in prying an area where there was one and it broke. We need updated images with those details. If I can I will do do when I reassemble.
