Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Loosen the seat clamp by pulling the black lever away from the frame. Once this is done, simply rotate the lever counter-clockwise to loosen the seat.
Now that the seat is loosened, slowly pull up on the seat cushion until it is fully out of the frame. Next, place the seat on the ground.
Use an Allen wrench to unscrew the bolt that is holding the post to the seat cushion.
Now that the bolt is loosened, carefully pull the seat cushion from the post. Next remove the two riders as shown in the second image.
Uma outra pessoa concluiu este guia.
